dmacy
(David C. Macy, CMI)
April 18, 2007, 5:27pm
What would the cause of the corrosion above the furnace? There was also some debris below the flue on top of the cabinet and the flue looked fine with no evidence of corrosion.
There is no central air.
Could it be high humidity. Dirty ducts.
I dont know & need some help.
Thanks
jwilliams4
(Jae Williams)
April 18, 2007, 5:38pm
2
Condensation can collect there. The “corrosion” could be airborne particles that remain after the moisture has evaporated. Same with the rust.
mberman
(Matt Berman, CMI)
April 19, 2007, 12:04am
4
You could get moisture from a crack in the heat exchanger,How old was the furnace.Matt
dmacy
April 19, 2007, 1:42am
5
12 year old comfort maker. Heat exchanger not visible to inspect. Flame pattern looked good.
