Originally Posted By: jhagarty This post was automatically imported from our archived forum.
A. Inspect or evaluate interiors of flues or chimneys, fire chambers, the heat exchanger, the humidifier or dehumidifier, the electronic air filter, solar heating systems or fuel tanks.
Originally Posted By: clawrenson This post was automatically imported from our archived forum.
It is important for inspectors to clearly state in their report how the unit was inspected, and more importantly what limitations were present during the inspection of the furnace. Example - how much of the actual heat exchanger did you view. What was its condition, etc. Did you test the unit, what did you see, smell or hear during its operation?
I also noticed it was a "Chrysler" furnace that could possibly date back to 30 or 40 years. That's well beyond the normal life span of most standard efficiency units. In addition did you try to gather information such as information from the furnace data plate - which might provide some clues to its age. Were there any signs or evidence of maintenance?
Often we need to understand and respond to more than just the basics in our reporting to avoid situations like this from coming back to cause grief later.
That is where limitation clauses such as Joe and David's notes can help set realistic expectations of the reality of the inspection.
Originally Posted By: rbennett This post was automatically imported from our archived forum.
Tyrone
A cracked heat exchanger is bad but they have been known to run a long time without health problems – I know because I ran a cracked heat exchanger for two years. Yes, I monitored the air in the house very close. (Carbon Monoxide) Here is the deal – the blower tries to blow air into the crack keeping the gases from getting into the house. Where the problem starts to get bad is when the blower starts to blow the exhaust out the combustible air intake. (Bad news) One has got to keep the stack vent in very good condition.
1 — You told your client that it was old and at some time was going to have to be replaced - or something like that
2 — Make him show you the crack - it is only fair
3 — Heat exchangers can be replaced and in some cases repaired
4 — With the knowledge that the furnace was on its last legs, did he get a $$ reduction based on your report from the seller?? - You have a right to know
5 — With the knowledge that the furnace was on its last legs why did he not ask for $$ from the seller? - That is why he had you do the inspection
IMO -- Do not try to hold me up for a whole furnace for a crack in the exchanger. -- If you are to replace it you have a choice of what type (cheap) pro-rated on age -- etc. -- Like find out what the TRUE cost should be.
In short I would be fair but don't bend over and get out the check book yet. Work with your client. If he won't you can be just as firm in your position as he can. -- He does not want to spend too many extra $$ to go after you for a $1200 furnace
Make it a win - win thing for both -- At this point you can't go back and re wite your contract with all types of disclaimers. You can only do with what you have got.
Remember what you hear the this board is just our thoughts -- talk to a lawyer, most will give you a SHORT visit for free.
Go for it and let us know how it goes - You will then be the knowledge expert -- not us
Originally Posted By: twheeler This post was automatically imported from our archived forum.
I appreciate all the responses.
I do have a disclaimer for heat exchangers in my inspection agreement. I also noted in the report that the furnace inspection is limited to a visual inspection only, and that we offer no guarantee or warranty of any kind.
Originally Posted By: Gary Reecher This post was automatically imported from our archived forum.
Agree. Get with your lawyer about writing disclaimers.
Ellis Prach who conducts "Heat Exchanger Experts" classes where he travels around with 50 some different brands and models of heat exchanger. Stated of one individuals furnace that he inspects annually. About a month after annual inspection the gas valve went out and he did another inspection on the heat exchanger and it now had a 7 inch crack that wasn't there the month before.  Granted the furnace was 30 some years old but he illustrated just how fast a crack can some times develop in just a short space of time.
Originally Posted By: dandersen This post was automatically imported from our archived forum.
to you, reiterating inspection contracts, inspection reports which indicated the condition of the unit and provide a copy of the NACHI sop. That should be sufficient to show that inspection of the heat exchanger is outside the scope of the inspection. If they so wish to continue with this matter and hire a lawyer then you’ll have to respond to their complaint and get a lawyer. Use care in correspondence with the client. They are out to get you and you do not have to prove your innocence, just state the facts. Whatever you write will be seen again if they litigate the case. Keep it short and sweet and stick to the facts that have already been provided to them. You are just reminding them of what already has been written and said. Outside of this, wait to you get to court.
It is common for HVAC contractors to fuel these issues when they indicate "your inspector should I found this", when they have no clue what a home inspector does. You may want to contact the technician and determine exactly what type of where the crack is. Often, face plates within the burner compartment crack which have little or no bearing on the operation or safety of the equipment in some cases.
Remember, you have 10 days to return and inspect the complaint. I suggested you do this, take photographs of the burner compartment and anything to support the condition. If the heat exchanger has already been replaced, they are operating outside your contractual agreement stating that you have the right to inspect the equipment before it is repaired. If they do litigate against you, they're going to go after you for negligence not for contractual issues. It's their responsibility to prove that you were in fact negligent in your inspection, which Nick or Mr. Ferri can support you as to how home inspections are internationally conducted.
Good luck, and try not to lose too much sleep over it.
Regardless of how good of job yor are doing with your inspections, these things always pop up. It's the nature of this beast.
The problem associated with returning to do a visual is, it is below zero outside, so because the heating company “red tagged” the furnace, the gas is shut off and not to be turned on unitl the furnace is replaced. Therefore, the customer has to get a replacement as soon as possible.
Yes, that would fall into an area where they are allowed to fix the heat ASAP without waiting for your reinspection, however if you can fit it in, I recommended you do get one done.
I would at least contact the HVAC company and try to determine the conditions leading up to any extent and location of the cracking.
HVAC contractors are required to red tag any furnace that as a potential safety issue. However, HVAC technicians have been known to go overboard to sell some new equipment, especially when dealing with a piece of equipment as old as this one. Some of them just don't want to fix it.
I highly recommend that you get back in there and see the furnace even after it's been replaced (could be at the HVAC contractors place of business). Actually after replacement would be best as you can see down inside the furnace as to the extent of damage. If the damage turns out to be minimal or not visual even after the equipment has been removed, this would be a good defense on your behalf.
New Update!!!
The owner contacted a reputable HVAC tech. He installed a new furnace right away, and told the clients that I did all I can and that there was no way of determining when the furnace would fail.
The clients then contacted the Real Estate agent and told them that they should have read the signals and replaced the furnace upon moving in, and that in fact the report indicated that the furnace was old.
So there is no legal reprocutions, and I received a compliment for acting so fast in giving them a name of a HVAC tech that acted very fast.
Originally Posted By: dbowers This post was automatically imported from our archived forum.
as a longtime inspector knowing what 3-4 items are my biggest liability in a HI - there is NO WAY that I would have walked away from a furnace of that obvious age and NOT recommended a "competent & licensed heating contractor verify the integrity of the HE prior to closing (due to the age, rust spots, rust on inner surface, the color of the flames, debris in the burner compartment, known failure of HE’s over 20 yrs old, limited view of HE, etc).
Do yourself and your clients a BIG favor in the future and get tight!!
