Originally Posted By: jmichalski
Weekend inspection and I found three areas of cracking in the foundation. One is a diagonal 1/32 inch width running on the side wall from the window tot he base of the wall near the sump pit (about 8 feet in length - did not photograph well).
The second is a vertical crack on the rear wall that seemed fairly typical.
About two feet to the right of the vertical crack, at the corner of the foundation was another crack.....
Then near the front of the home, under the stairs there was this diagonal crack which was nearly 1/4 inch at the top.
The home is only 4 years old and I recommended contacting the builder to determine if the foundation is under warranty. My client is understandably edgy about it, so I recommended an SE as well for his peace of mind.
Any thoughts? Did I overreact to his jitters?
Also, I know the rule of thumb is that vertical cracking is usually not a structural failure, while horizontal is. I could not find a good authoritative source to quote however - anyone have any help? Or a good blurb they use in their reports to cover this type of cracking when observed?
Thanks!!!
