mdeacon
(Mark Deacon)
February 24, 2010, 12:38am
Crack appears on both sides of the foundation. I’m told this isn’t a structural concern and I haven’t been able to find any information on it but I’m not convinced.
Unfortunately, I can’t upload pictures right now, but I will try and describe it.
Thin crack vertical through approximately 4 foot block foundation, no damage to the brick veneer above. On the other side (In the garage), a think crack in the same location.
Any opinions?
clawrenson
(Claude Lawrenson)
February 24, 2010, 1:31am
2
Did you observe a consistent thin crack, or one that gets wider as it goes up the wall?
Length of the crack?
Approximately how old is the structure?
mdeacon
(Mark Deacon)
February 24, 2010, 1:34am
3
clawrenson:
It appears consistent, length approximately 4’. Age of structure approximately 20 years
jfunderburk
(Joe Funderburk, CMI)
February 24, 2010, 2:46am
4
Need a pic.
(I can’t give a haircut over the phone either.)
mdeacon
(Mark Deacon)
February 24, 2010, 2:48am
5
It’s not letting me upload pictures, just keeps saying uploading. Can I e-mail the pictures to someone?
belliott
(Bob Elliott, 450.0002662)
February 24, 2010, 3:26am
6
Mark you need to reduce the photo size before uploading.
Look at the file size limit box.
mdeacon
(Mark Deacon)
February 24, 2010, 3:43am
7
Thanks Bob,
Here’s the pictures.
The inside picture is all that was visible. This was in the middle of a shelving unit. No visible cracking on the floor. No basement below.
On the outside, no cracking on the brick above.
mdeacon
(Mark Deacon)
February 24, 2010, 3:47am
8
I’ll also add that the current owners but the house in 2002 without an inspection and were unaware of the crack.
belliott
February 24, 2010, 5:03am
9
Typical settlement crack.
Looks like a plug and seal job is needed at most from the information…
jevans
(John Evans)
February 24, 2010, 10:04am
10
Agree with Bob, very typical crack. I always recommend sealing to prevent moisture and insect intrusion.
mdeacon
(Mark Deacon)
February 24, 2010, 1:07pm
12
Ok thanks, so even though the crack is most likely going through the block, there’s no structural concerns?
jfunderburk
February 24, 2010, 3:18pm
13
Masonry is very unforgiving. Any slight movement will crack it, often along the mortar joint, but not always. All houses settle to some degree.
