Cut Valleys
Fellow NACHI Inspectors…
What is the consensus on cut valleys in regard wo which roof plane shingle goes on top (and is cut)? If the lower roof, like a dormer, is steeper pitch than the upper main roof. I’ve read the upper roof goes on top (more water shed) and read the steeper roof goes on top. If the ridge lines are equal, I’d go with the steeper option I get that…
What is everyone’s “cut-feeling”?
Thanks
Jeff
In the attached photo, both pitches are the same and while I wrote up the main roof should overlap the lower in the cut valley, I didn’t make a huge deal of it and now the seller called the contractor who is PISSED… LOL
:shock:
California valley…Fine.
The larger or the steeper roof plane gets the cut. If those are the same slope, they did it wrong.
Brad, that is my understanding as well. (yes same pitch)
which takes precedence Steep vs. Higher? for example if this lower/smaller roof was a steeper pitch?
The steeper plane gets the cut, even if lower. If that dormer had a steeper slope, then it would be correct. You always want the least amount of water runoff or force against the edge of the cut. It wouldn’t matter on a weave or a metal open valley.
How come you know all this stuff
Mastering Roof Inspections: Asphalt Composition Shingles, Part 23 - InterNACHI
https://www.nachi.org/forum/data:image/png;base64,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
Larger plane with the greater volume of water overlaps the smaller (per Certainteed). Those are so similar that I wouldn’t have commented. Cut line should be 2 inches above the center line so that it’s less prone to trapping debris. You could argue that you’re correct, but IMO its moot on this roof.
Its fine and dandy to inform your client that the shingles were installed wrong but lets be honest and Realistic here do you really expect the seller to tear off and reinstall??? I see wrong cuts quite frequently and nothing is ever done about them. BTW we call them Texas cuts;-):wink:
(Chuck Evans) I noted it in the report that I was technically wrong but may not be a problem moving forward. I suggested they keep an eye on it and since the back roof needed to be reroofed anyway, that would be a good time to review it again (i.e. monitor conditions). I told them I don’t believe it’s worth changing. but since the roofer was called out to fix the deteriorated rear roof, somehow he got wind of this comment and made a fuss. All is good…
my question was a technical question on what is correct. I am sorry if you misunderstood my question. I did not tell anyone to tear off and reinstall… in fact I told them while technically wrong, it was likely fine, just to keep an eye on it… of course this was the day after we saw this other one… so we were sensitive to the problem.
OKie Doke!
The cut goes on the side spelled out in the manufacturer’s installation instructions.
Yes, that’s a California cut valley. You can see the pattern in the shingles that lie parallel with the valley.
On a cut roof it gets cut back on the side with the greatest volume or velocity runoff.
Just like if it’s an ugly, crooked cut, if it’s cut back on the wrong side, that’s a sign to look for other problems on the roof, because you shouldn’t call for correction of that small a problem, because they’re not going to do it and you’ll just create bad feeling.
You could check to see if it’s sealed along the cut against cross-wash.
