Doing an inspection yesterday, recently completed deck- a lot of problems- no joist hangers, beam to post connections, joist -ledger board connection-missing support beam-can’t imagine it passed an inspection- homeowner didn’t know- probably no permit. Anyway, 6x6 PT posts - there are 2 actual 6x6 PT posts- the rest are built up 2x6 dimensional pt lumber- I see in the building code it is still ok to bury PT posts, but no mention if built up post is OK? Any comments please?
Built-up posts should not be used for a free standing application like a deck, because due to their fasteners they can fail prematurely sooner than later. This is not prescribed by AWC (https://www.awc.org/pdf/codes-standards/publications/dca/AWC-DCA62015-DeckGuide-1804.pdf). You should inspect decks using their model and anything else needs to be prescribed/approved by an engineer. I would defer the entire deck and write it up hard based on what you wrote. Let someone else “okay” it.
Perhaps that was worded somewhat misleading. I did not mean the deck is a free-standing type. I meant when used to support a deck the posts have no support and are thus free-standing – nothing else is supporting them.
