system
(system)
August 17, 2004, 12:00am
Originally Posted By: chorne This post was automatically imported from our archived forum.
http://www.nachi.org/bbsystem/usrimages/more/100_0182.jpg ]
system
(system)
2
http://www.nachi.org/bbsystem/usrimages/more/100_0183.jpg ]
system
(system)
3
Originally Posted By: jpeck This post was automatically imported from our archived forum.
Carla,
you mean like this?
By the way, all that paper facing on all that insulation ... this is what those warning labels say.
Image: Paper and foil facings need to be in contact with gypsum board or other approved building material ]
-- Jerry Peck
South Florida
system
(system)
4
Originally Posted By: Guest This post was automatically imported from our archived forum.
Judging from your photos it’s not flashed at all. Just as bad, I can almost guarantee it’s improperly attached.
system
(system)
5
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
I didn’t note any sill seal either?
–Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
6
Originally Posted By: phinsperger This post was automatically imported from our archived forum.
Kevin,
I think I see the sill seal. Its blue
Paul Hinsperger
Hinsperger Inspection Services
Chairman - NACHI Awards Committee
Place your Award Nominations
here !
system
(system)
7
Originally Posted By: rpalac This post was automatically imported from our archived forum.
What is on the out side?
What is over the top where the water mark starts?
It’s obvious that the water is penetrating through at some upper area that is on the other side of that wall and running down.
Bob P.
Water leaks are hard to find, even in a submarine.
system
(system)
8
phinsperger wrote:
Kevin,
I was guessing that blue line to be the chalkline to set the wall on, but now see on one photo how fat it is and you're probably right.
--Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
January 19, 2005, 12:00am
9
Originally Posted By: CarlBrown This post was automatically imported from our archived forum.
To see more pictures of lack of detail go to
www.badstucco.com – If it was your house wouldn’t you want the best!!
system
(system)
March 1, 2005, 12:00am
10
Originally Posted By: Matt Butcher This post was automatically imported from our archived forum.
The Blue Sill Plate is a product called Sillbor. It is a borate treated product used mainly in humid areas. Due to the elimination of CCA and because of the many complications being reported with ACQ eating through fasteners many home builders in all areas of the country are turning to this Sillbor product. It has a trademark blue color.
system
(system)
March 2, 2005, 12:00am
11
Originally Posted By: kwilliams This post was automatically imported from our archived forum.
to NACHI Carl and Matt
--Member - MAB
http://www.nachi.org/convention2006.htm
