Does anyone have a deck only inspection they would like to share that is Spectora compatible?
Thank you in advance
Just duplicate your main template and delete out everything but the deck stuff and rename the new template as your deck template.
Your stalker hasn’t posted yet? Must be painting his toenails…
And this helps the association, the message board and reads thereof, how?
Thank you Ryan, already know that trick. I was wondering if there was a more comprehensive version that covered stuff like type of fasteners used to joist spacing for the information section. I can use all my previous defects. Just looking to give the client their moneys worth for only inspecting their deck. by recording as much info as possible so they can they turn that to a contractor.
I could see where that would be nice for a deck-only inspection. I don’t have one to share with you, but if you need any help/advice for adding these types of info comments, just let me know!
Just some ideas…
Ledger size
Ledger fastener type
Ledger fastener spacing
Ledger attached to:
Joist size
Joist hangers present?
Hanger fastener type
Joist span length
Joist overhang (cantilever) length
Beam type
Beam size
Post type
Post size
Footing type
Footing size
etc
etc
etc
PM Robert and I’ll explain…
These are good examples/points, make a detailed inspection of the existing deck specifics and build/add to your template from the references you have (or research) to add to your template.
Here’s one reference…
Awesome! Thanks Ryan and Dave. That is where my brain is going. Sounds like I will just have to buid something out. No biggie, just checking if there was a cheat code.
Client bought the home 2 years ago and seller report was very vague about deck issues. Client would rather have another inspector come out to provide a report of deficiencies and potential repairs over a deck contractor that is just going to want to build them a new deck.
Here’s another one…
Or buy a template database from one of our esteemed members. This will be a comprehensive template though, not just deck specific narratives.
