What is the difference in standards for the maximum height of a stair riser for interior stairs between that mentioned in InterNACHI’s How to Inspect the Attic, Insulation, Ventilation & Interior Course, and that mentioned in InterNACHI’s Healthy Homes, Part 6: Housing Structure Course?
In the How to Inspect the Attic, Insulation, Ventilation & Interior Course, the maximum tread height is 7.75". At the same time in the Healthy Homes, Part 6: Housing Structure Course, the maximum tread height is 8.25".
Which InterNACHI standard is correct?
Here’s a screenshot from the How to Inspect the Attic, Insulation, Ventilation & Interior Course:
Why they have 8 1/4 in the Healthy Home course I have no idea. You’ll have to ask whoever wrote that. Maybe they figure you’d be more healthy if you have to climb steeper stairs.
I read that you were the comparing “How to inspect the attic etc.” versus “Healthy Homes etc.” My point being, when do you find a standard interior stairway leading to the attic? Simple question to look into. Don’t get too tight about it…
Many older (1940 earlier) Victorian style homes in this area have built in stairs to the attic, even when the attic was an unfinished space. Made it much easier to use for storage.
7.75” for other than Masonary stairs. Masonry stairs at the exterior may be as high as 8”. The 8.25” riser height may have been an old IRC code for Masonary riser height.
That could explain the discrepancy.
However, Indiana Residential Code probably should not be considered modern building standards for InterNACHI when International Residential Code gives a different standard.
After sending an email to [email protected], Ben Gromicko emailed me a Loom video update. Basically, Ben said that the Healthy Homes, Part 6: Housing Structure Course was outdated. The IRC standard for stair risers changed in the year 2000 changed from 8.25" to 7.75". As such, Ben then showed me that he updated the course as a result of my inquiry to show that the modern standard for stair risers is indeed 7.75".
Yes, I do include in my agreement that I follow InterNACHI’s Residential SOP.
Thanks for the update Adam. We have many row homes in the city at or over 100 years. In those days stairs were often built to fit whatever space they had available. This created many steep narrow staircases and people moved furniture just like the Laurel & Hardy movies, with a rope through a second floor window.
