The home owner has wired his bath exhaust fan with a lighting dimmer switch, the kind that is push-on, push-off and you can vary the current to a bulb. Besides being bad for the fan motor (or is it?), is there any danger to the homeowner? I’m thinking the switch could overheat?
Using a dimmer switch to run the fan motor is not a good idea it will destory the motor and can ruin the dimmer switch.
However if that is a motor speed control it may be ok depending on what namebrand the exhaust fan is and typically with motor rated speed controller it will slow down the fan motor a bit but when you slow down the fan you will really loose the performace pretty fast.
Pretty sure it’s a light dimmer by the appearance of the knob and the on-off feature. Now I’m wondering if it can cause a fire by the motor drawing more current than the switch can handle.
Given that the power required by a fan is related to the cube of the speed (I think I am remembering that correctly), slowing the motor will reduce the motor current considerably. If that is the case the motor will probably survive ok. I would be more concerned as to whether the current rating of the dimmer is adequate for the full speedload.
All that aside, why would anyone need a variable speed bathroom exhaust fan?
