Does this scare you
I wasn’t thinking about the 3 phase, 208 volts aspect when I did the calculations.:roll::shock:
Didn’t wait to see if that was working. I immediately shut off the breakers and told the RE agent to call the vendor, tell them what was found and why I shut it off.
BTW…I check the individual elements for continuity as you do.
Another good man:D:D
Agree!
First he used his hand and then tested to confirm.
A simple voltage ticker would have suffice though, in this situation.:wink:
Would of made better contact if he had used his tongue.
If he had used his ticker what about the 120 volts from the other side of the line that would be present me thinks the ticker would have indicated voltage.
Do you just not like amp meters or do they just not sell them in your neck of the woods:D:D
Are you going to teach us the lick test now.
I have my pencil and paper handy.
No I think Jim McKee is the expert in that field
Charley,
I have one but rarely use it.
Actually that is not true, I used it once to find out how much it cost to operate my swimming pool pump motor and furnace ventilation fan.
Shortly afterward, I bought a timer for the pool and turned the furnace ventilation fan to auto. It paid for my meter many times over.:slight_smile:
Now it all starts to make sense Mr.Bottger.
Jim said his sense of taste is gone and his tongue is afoul and black when I got the chance to see it when he is talking.
He said he never uses clamp meters when doing are amp meter drop test.
He Likes the lick test. Says it is more accurate, but he can only do 1 a day.
HA HA HA HA.
On some wiring installs you would need to isolate the heating element. If you don’t you can be reading back through other parallel loads. Ammeter on each element is the fastest.
