Yeah you could call out ground neutral branch wiring. Neutrals should be alone grounds can be as many as rated. That’s wrong in every panel in my area. I don’t get too worked up about it. Surge protector I can’t tell. Good luck
Neutrals should not share a terminal with bare grounds. Bare grounds can share a terminal.
Can’t tell from the pic, but it looks like the Surge Protector is double tapped at the two pole breaker? Some Square D breaker terminals are designed for two wires, you’d have to look at the diagram on the breaker, or on the panel drawing
