Double tapped neutral
Hey Guys,
Is this what we call a “double tapped neutral”? Looks like it, but I see this very often. I see this almost every week. Is this something that should be called out as a safety issue or a defect?
Yes that would be called the slang term “double tapped”. It’s a violation and should be called out as such.
Double lugged is the term I use for multiple neutrals under one screw.
I see this very often. Should I recommend evaluation by a licensed electrician?
That multi lugging seems like it wasn’t done by someone knowledgeable in the profession…I mean, look at all the open lugs available. I would recommend repair by a qualified electrician. You already evaluated it. :slight_smile:
It is incorrect and a code violation. There is no need for further evaluation…
Just to add, that appears to be a ground bar, not listed for neutrals. Notice the lack of insulation. Of course if this is a meter can combo it might be ok since I see those frequently in contact with the can and listed for use a neutral bar.
I saw it again today.
Here is the graphic from the code article from Mike Holt
data:image/jpeg;base64,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
