I’ve attached a new draft image to preview, before finalizing. I’d like to hear any valuable feedback from the forum. Thanks for your help!
Looks great to me, Zak!
Looks good
Hi Zak,
The medium profile tiles (AKA “M” or “double roll”) depicted are installed straight bond. This type of tile (in my area) is typically required to be installed staggered with straight bond installation being discouraged.
Here’s an example of staggered (low profile/flat) tile.
The “Gaps filled with cement mortar or roofing putty” are typically referred to as areas requiring “weather blocking”. Battens (of thousands of tile roofs I’ve inspected, I’ve seen one with Battens) are typically segmented to allow any water that gets under the tile to drain.
The Tile Roofing Industry Alliance (TRI) provides the installation standards for Clay and Concrete Tile roofs CONCRETE AND CLAY ROOF TILE INSTALLATION MANUAL Published by the TRI Alliance - March 2024 Uniform ES-ER-2015
Florida has it’s own installation manual with specific requirements related to hurricane mitigation.
Florida High Wind Concrete and Clay Tile Installation Manual 7th EDITION FRSA–TRI Alliance December 31, 2023 (12-31-23)
The “Underlayment Rules” may vary by manufacturer and location.
