What can you guys tell me about paint bubbling on stucco that has calcium chloride in the stucco mix?
I can tell you that the stucco was probably installed in the winter. :mrgreen: Might have been painted during similar temperatures, which may be the root cause of the bonding issue.
Thanks Mark.
The stucco was done for sure when it was to cold. The painter did not paint it when it was freezeing.
My understanding of CC is that it eats metal and I am curios if it could be the issue with the paint.
Carl, was it painted within the first 90 days of it’s installation/
Was it patched and not primed?
Moisture will tend to make paint bubble and blister.
Just throwing possibilities at you.
Marcel:)
Marcel,
The painter said he let it sit for 45 days.
The subs tend to be at the builders the mercy. Kinda do it now or I will have someone else do my work.
I have seen stucco painted the day after it was finished because the homes parade was that weekend!
Did you install the stucco?..:mrgreen:
The inside of the wall will look like this shortly…
No sir I did not!
Looks like someone has some bad woodpeckers!
Ahh, don’t we all love that OSB without a rainscreen.
Dale, aren’t you being a little to invasive on your inspections? ha. ha.
Carl, at least the calcium chloride did not rust the wire lath, but sure did a number on the sheathing. ha. ha.
Marcel
Dale found that picture somewhere else, probably not it Arizona because they use chicken wire.
Carl, I didn’t think they raised chickens in Arizona!! So where do they get their chicken wire?
http://upload.wikimedia.org/wikipedia/en/thumb/1/1c/Chicken_wire.jpg/180px-Chicken_wire.jpg
http://en.wikipedia.org/skins-1.5/common/images/magnify-clip.png
Chicken wire
I thought it was this.
http://www.cemcosteel.com/uploads/images/regular/6.jpg
Is this another one of your Hood tricks? ha. ha.
I think Dale missed the Chicken, and stumbled over the real thing.
Man you guys are good. ha. ha. ![]()
Marcel
I bet Dale does not miss a meal!
Well I call it chicken wire…
So does the city building inspector…
No wonder I hadn’t seen our inspector recently, he moved to your area.
Now Dan,
I thought they were all still here! Who does that picture remind you of?
