1. BEFORE TOUCHING ANYTHING ... wherever possible, put one hand in your pocket (I understand the left is better) ? or at least think that way (like keeping one behind your back).
2. BEFORE TOUCHING ANYTHING ... remove all rings and jewelry, and turn off your cell phone or beeper ... it could startle you when you need to concentrate. [added]
3. BEFORE TOUCHING ANYTHING ... make sure you have the required 30" wide by 36" deep clear working area in front of the panel, or request things be moved. [added]
4. BEFORE TOUCHING ANYTHING ... check for voltage on the panel and on any pipes/conduits around the panel with a voltage ticker and meter.
5. BEFORE TOUCHING ANYTHING ... always check around the panel for cables entering without fittings (possible nicks/shorts), burnt/scorched wires, panel grounding, and scorching around panel screws (panel screws may have contacted wires inside ... especially the long ones "Harry Homeowner" installed). The horror stories I could tell ... lol.
6. BEFORE TOUCHING ANYTHING ... make sure you have eye protection and at least 3 layers of insulation protection (options include no "apparent" power, insulated tools, electricians gloves, insulated work boots, and dry location/platform ? I am a big fan of using the small electrician gloves, eye protection and insulated boots, no matter what, anywhere near electricity). And you do NOT want to possibly be "grounded" like in a wet basement anywhere near electricity. [And use a nonmetallic flashlight.]
7. BEFORE TOUCHING ANYTHING ... look at the type of panel, where you are, and what might happen if you do remove the cover. Some types of panels have breakers that might just pop out and a separate frame ring that can drop on to the main service lugs if you are not very careful (any guesses on what type of panels?).
If at all possible, have a sparky walk you through a panel inspection. And I know others have said this, but let me repeat the mantra here ... DO NOT TOUCH ANYTHING INSIDE A PANEL OR STICK ANYTHING INSIDE A PANEL!!!!!!! ?
Use common sense, and look for things that don?t look right. If you are not sure what you are doing or something doesn?t look right, bail to an electrician. It is okay to note in you report ... "full electrical panel inspection appeared unsafe ... it is recommend that a licensed electrician inspect the panel".
Maybe some sparkies could jump in here too on the safety issues as a reality check and if I missed anything. And check out the ?NACHI Tip of the Day? as there are some good ones relating to services and panels.
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
