This a first. Overhead service wires attached to a 7’+ mast and attached at about 5’, wires run to the drip loop and enter the home through the main weatherhead. Attachment of wires to the mast is with electrical tape.
Dakota,
The electrical tape will deteriorate leaving the cables to wear on the mast. I would definitely refer to a qualified electrical contractor. Good catch.
Initially a thought of mine as well, but I’ve also had experiences where the trusty zip tie after a little bit of UV exposure becomes quiet brittle and worthless. Thanks for the input!
My pleasure, Dakota.
My interpretation is POCO is not responsible.
As for secured cables. As log as the cables are secured to the mast in such a way that will not negatively affect the insulator jacket, damage or kink the cable or effect personal safety, then Bob’s your uncle mate or, “you’re all set”.
