Originally Posted By: sramos
Thank you for your reply Bob. When you say radically different readings between circuits, do you mean between outlets on the same circuit (i.e. two outlets in the bathroom).
Next question, in the absence of proper labeling at the service or distribution panel, how can you be sure the any receptacles are on the same circuit?
With respect to resistance, the Suretest does measure resistance. However, I beleive it measure the entire circuit not just that receptacle. I guess could use both measurements to ascertain where a high point of resistance begins, if you new which receptacles where on the same circuit?
Steven Ramos
EnviroVue Home Inspection
866-541-2883
