This is my home but wanted to post as most do not pull off covers as it is not required in a non invasive inspection but I have the following improper electrical practices.
exterior light with no visible junction box and lacks ground connection.
updated lights and switches lacking the ground connections.
So if you were doing an inspection on an older home and was noticing some open grounded outlets would you also mention the lack of a ground at the lights and switches if they had been modified?
Also did an inspection for a client how lived in the home and they used drywall screws to secure the receptacle to the outlet. I would not of known if he did not tell me as he lived there. (Last pic)
I added a exterior box designated for a wet location but it stall lacks a ground.
While the splice for the flood is now contained in a box there are still issues like the lack of a connector and the cable sheath does not extend into the box.
I hear you. The wires in contact with the metal soffit is not good. Not much room to crawl around up there to rewire. It is on my list for the electrician.
One of the first things I did about 8 years ago. I hate it.
Any recommendations for type of fixture? It is between garage and kitchen. The other side of the family has a remote control ceiling fan that is also not grounded.
David I would need to see the space however there are so many cool fixtures out there it is amazing.
Some of this LED stuff is looking good.
You now have remotes for changing cool to warm tones.
I used to build my own.(No UL approval)
Trac lighting and wall sconces add certain atmospheres however chandeliers would not work in a family room.
If you have a flat screen go with trac to avoid screen washout.
Those lights are (but not really) referred to as boob lights for obvious reasons! LOL As Bob said bedroom lights usually or a hallway. Because they are cheap allot of builders use these fixtures …I used to get 6 in a box for $39.00 at HD.
Most of the new lighting fixtures cannot be used with 1960’s wiring. They will typically say on the box or in the instructions that the conductors must rated for 75° C or 90° C.
