I broke a chain while testing auto-reverse feature once. Paid the bill and I no longer test for that safety feature anymore. Luckily it only cost $150 so my inspection was still profitable.
Not worth arguing with the home owner or agent. Paying for the damage is doing the right thing and saves you from having a bad reputation.
I have seen many garage doors that have the bottoms pushed up in the middle. I assume it was from a previous 2 x 4 test. I test the electric eyes and do not test the pressure switch.
Here is my report comment…
“The garage door pressure-activated auto-reverse function was not tested because it may cause damage to the garage door and/or its components.”
One thing to note is that the manufactures don’t state that this test will not damage the door. The mechanism is meant to prevent injury or death, not meant to protect the door/opener. Unless the pressure is set ultra-light, some level of damage will occur to the door and/or opener when performing this test.
So to summarize its probably best if I don’t do the pressure test and just stick with the light sensor test? Cause atleast that way if it breaks it was definitely using normal operating controls and I could easily argue that i was just finding a latent defect.
