Does any one know the fire rating of 3/4" particle board? It is being used as an attic access lid in the ceiling of an attached garage.
Thanks.
Thanks.
Al, the fire rating requirements should match the one-hour separation between the house and the garage.
If the house/garage separation is all the way through the attic and to the roof, then the particle board hatch in the garage ceiling would be OK.
If the attic is open to the garage attic, you would require a one-hour rated ceiling in the garage including the hatch.
This link might help share some information on fire resistant materials.
http://www.dps.state.la.us/SFM/doc_flamespread.html
Marcel
Fire ratings, or more properly fire resistance ratings do not derive from one component, but from an assembly of components which has been tested in accordance with established procedures. A piece of 5/8 Type X gypsum board has no “fire rating” whatsoever…it could be part of an assembly of components such as framing studs, insulation, and at least another piece of gypsum board on the other side, and that assembly may or may not have a fire resistance rating.
Your particle board, being combustible, probably cannot be even a part of a fire-resistance-rated assembly. It certainly has no “fire rating” whatsoever, on its own.
But it is a lot more than the 1/4 plywood cover of most pull down stairs.
You are right Bruce, but I think Richard is talking about fire resistive ratings to this affect.
5/8" Type X Gypsum Wallboard Standards, Testing, and Certification
Summary
Marcel:)
Just HOW is it being used as an attic access in the ceiling of an attached garage?
Under what building code does your jurisdication operate?
If the garage attic is separated from the house attic by 1/2" drywall then it does not matter what or if the access lid is ‘fire rated’.
More information needed.
While I am initially siding with Richard Hetzel…
What the original poster has supplied to date is meaningless…
And what Marcel Cyr posted even moreso…
Sorry…
We used this or FR ply for signage backing years ago, some munis accepted it and some didn’t
http://www.landmark-products.com/duraflake_fr_spec_0405.pdf
Fire-proofing in a garage is not complicated.
OSB is a combustible and can not be utilized for fireproofing. Fireproofing material must be 5/8" fire rated (type X) drywall or better.
Simple Illustration…
“Click to Enlarge”
**R309.2 Separation required.**The garage shall be separated from the residence and its attic area by not less than 1/2 " gypsum board applied to the garage side.Garages beneath habitable rooms shall be separated from all habitable rooms above by not less than 5/8 " Type X gypsum board or equivalent.Where the separation is a floor to ceiling assembly , the structure supporting the separation shall also be protected by not less than 1/2" gypsum board or equivalent. (not Type X per se)
For an older style attic access cover, in the garage or living space, replacing with or laminating 1/2" drywall to the particle board lid would be a reasonable recommendation.
I don’t think we should or have to exaggerate this into a “deal killer”
hombild,
yet again your post makes no sense.
I have an idea Marcel has forgotten more than you have proven that you know.
This might help…
Thanks Randy,
I posted the same thing up top and is not quite good enough for some non-members that think we little home inspectors don’t know anything, because he is a Code Enforcement, but can’t read in between the lines.
Funny how some are code enforcement and can relay educational points to this board and some can’t.
I wonder if as a Builder he is building in the same Jurisdiction as his Code Enforcement Duties? hmmmmmmmmmmmmmm
Now that is a good question, isn’t it?
Maybe we should talk about ethics, maybe he knows nothing about the subject. Well, I’ll take that back, I am sure people like that can BS there way around that to.
Marcel
Sorry Marcel,
I do see you posted the exact same PDF up there. I believe that is just the information the original poster was looking for.
Marcel,
You are the MAN!
We would rather keep you as our info source then letting the whole world know right now if thats ok with you!
Hats of to you!
