Is fire retardent OSB typical in duplex dwellings? I find lots of FRT sheathing (plywood) in older duplex(s). I am pretty sure the blackness I found todayis mold/mildew although I want to be sure it is not charcoaling. Thanks everyone and long live NACHI
Looks like mould! Is it active now or was it just in the first year or so while the building dryed out from damp wood/concrete and excess mositure migrated to the attic.
I tell clients to check the attic in colder winter weather and call me if there is excess condensation/frost on the sheathing…then we can work on the causes.
There are attic moulds that are green or white when active and leave a black stain like in your pics after they die. Active molds of any colour can be wiped off with a finger, so that’s a good test. Be careful scaring people when there’s just a bit of old stain on the OSB. Call for improvements to ventilation if the soffits are blocked, weatherstrip seal on the hatch, stuff like that.
I havent had much experience with Fire retardent OSB. I have seen quite a bit of FRT plywood that is deteriorated (looks black with white charcoaling). Just wanted to know if this new fire retardent OSB ( http://www.flamedxx.com/ ) does the same thing as FRT plywood deterioration.
The charcoaling/deterioration of FRT plywood sheathing sometimes blends in with mold/mildew staining. I am curious if anyone has had experience with fire retardent OSB and if it blackens the same way as FRT plywood sheathing does when it starts to deteriorate from high attic temperatures.
I think that is just a fancy word for mutt in the Lingual World. ha. ha. That’s what happens when brought up to close to my Canadian friends of New Brunswick.
If you let water continually get at any wood product (except preservative treated and rot resistant species), it’s going to support mould/rot. It’s just that OSB came on big in the last 20-25 years when building practice common sense went out the window (poor/non-existent flashing details) , houses got more airtight at the walls/windows (housewraps creating more stack/chimney effect for moist air to rise to the attics) without compensating with good interior venting practice (bath fans dumped into attics)…all these other items/problems were blamed on the OSB…Hell!, it couldn’t be me, the builder, causing this mould/rot from not knowing what I’m doing and that buildings have changed in nature…gotta be the poor sheathing.
I’d use OSB board any day…though not on walls…insulation sheathing only!!!
