What year did the IBC start requiring residential garages to be fire taped? I just inspected a 2008 single family with attached garage and it had bare drywall on the walls and ceiling. Anyone have an answer?? Mike Paule, Peoria IL
In many jurisdictions I inspect in… as long as all joints/edges of the sheetrock fall onto a stud, no taping is required. Those edges that do not, must be taped and mudded, not just taped.
No fire proof requirements in Canada as of yet. Gas penetrations yes.
Where are you from? Fill out your profile under quick links. You will receive better answers.
Greg, city of Calgary requires taping and mudding of residentual garages.
Mike, When I started in construction, 1985, I was a drywaller and we were doing one coat of tape on firewalls back then. Not sure what code was used then but I believe it was mandated more from the life safety code rather than the building code.
