Infraspection Institute’s Distance Learning Course, Infrared Inspections for Home and Building Inspectors. Normally priced at $995, the voucher covers the full course tuition.
The door between the living space and the garage failed to close by itself.
Modern safety requirements require that the door between the home interior and the garage be self-closing for safety reasons related to fire hazard and toxic fumes.
The door is meant to close on it’s own to keep off gases from entering the home.
The door failed this test and would not close fully.
The hinges on the top and bottom have springs in them to close the door. The hinges are adjustable so over time they loosen.
The door hinges will need to be adjusted or replaced.
