First time in 27 years NO INSULATION
I inspected a small house by a lake today that has no insulation on the roof or walls. I have seen many lake side houses poorly constructed to be used a few weekends a year. Typically the issue is when someone buys one of these houses to live in year round. I just about over looked the fact the walls and roof were too thin to have insulation. Typically there is no attic so insulation is limited to the rafter thickness. My first red flag was I scanned the ceilings with my thermal camera and the interior surface was around 89 degrees. The outside temperature was about 75 degrees, then while thinking what the hell is going on I could see the interior roof surface was the same as the underside of the roof over the deck looking out the windows, see the picture below. Looking closer at the roof soffit, which was not enclosed you can tell the the 1 ¼ bead board was all there was. Then I went to a door frame and and done the math the walls were 2 ½" thick, one layer of 1 ¼ bead board on the outside and one on the inside, no insulation. The reason I bring this up is this is so rare anyone could have missed this so put this in your brain as the impossible is possible.
I saw the varnish on the under side of the interior roof was bubbled up, which now makes since. The roof got too hot causing the varnish to bubble up.
Nice camp Randy. How much is the sale price? LOL
I would recommend this on the next re-roof job of the structure.
Attic Retrofits Using Nail-Base Insulated Panels
This project developed and demonstrated a roof/attic energy retrofit solution using nail-base insulated panels for existing homes where traditional attic insulation approaches are not effective or feasible. Nail-base insulated panels (retrofit panels) consist of rigid foam insulation laminated to one face of a wood structural panel. The prefabricated panels are installed above the existing roof deck during a reroofing effort. The layer of insulation provides the added thermal performance, and the wood structural panel provides the rigid substrate for installation of the roofing membrane. For this study, vented attics were converted to unvented attics.
https://www.homeinnovation.com/trends_and_reports/featured_reports/attic_retrofits_using_nail-base_insulated_panels
1100 SF, $255,000, 1.44 acre lot
Not a bad price on the water Randy.
Same construction as old '60s - '70s A-Frames using 2"x6" T&G planks… heated by woodstoves.
Jeffery, this house fits that timeline, built in 1966.
Randy, maybe a little different in my area, but buyers would snap that up just for the land/lot value with tear down rebuild in mind. A place like that on our lake would easily be listed and sold for $400k plus in this market…
Anyway, typical “cabin, get away build” for the period.
