rfessler1
(Ryan Fessler, HI10797)
February 10, 2020, 8:20pm
Check out this ladder. The curved railing along the top did not attach, and was unstable for use. It could technically be used as a support, but anyone expecting it to be sturdy might be in for a drop dead funny surprise.
are you aware of any codes about this? I could not locate any particular to this issue.
lkage
(Larry Kage, CMI)
February 10, 2020, 8:24pm
2
rfessler1:
You may consider reporting it as a potential safety hazard…staying away from codes altogether. Just a thought.
mboyett
(Michael Boyett, TREC #7290 (Ret) Boerne, TX)
February 10, 2020, 8:43pm
3
If you feel the need to cite code then the 2018 International Building Code States
And the 2018 International Mechanical Code States:
Note, the code specifies “rung” diameter and load capacity but not necessarily “side railing” specs.
rfessler1
February 10, 2020, 8:50pm
4
thanks guys. just thought I’d run it by the forum real quick
mcyr
(Marcel Cyr, CMI®)
February 10, 2020, 8:55pm
5
Reading material here for you on fixed ladders.
https://continuingeducation.bnpmedia.com/courses/alaco-ladder-company/reaching-the-roof-specifying-fixed-access-aluminum-ladders-for-safety-and-efficiency/1/
The top of the ladder should have been secured to the parapet walls or the rails should of come back down and anchored to the roof edge.
