What are the requirements for the freon lines as far as flashing at the penetration point ?
[ATTACH]
[/ATTACH]What are the requirements for the freon lines as far as flashing at the penetration point ?
[ATTACH]
[/ATTACH]Pitch Pocket
…and those are “refrigerant lines”.
Try these:
or:
or, look further here:
http://www.tophatroofkits.com
Usually see the tube type Larry, but David it has proximity to the flue so most likely needs a pitch pocket.Thanks.
Brain fart.
Also had a cavity large enough to see no insulation on the lines past the ceiling drywall of the utility closet .Can we say lack of insulation may cause a condensation issue at the ceiling ?
Most for sure!
And the flue will likely leak as well (seeing your in a snow zone). Can’t see it too well though.
I normally see this sort of thing…
some of You old guys are pretty smart…
Nah more fun arguing about marketing…LOL
Those are really nice.
That is what I used to use except for the factor top. We made a goose neck with long sweep 90’s. Never had a problem with leaks.
