Originally Posted By: kshepard
This venting was in a tract home built in mid 2005. Hard to imagine a building inspector walking right past it, but hard to imagine it meets code.
Kent
Originally Posted By: dbowers
Originally Posted By: rcallis
Originally Posted By: rray
Originally Posted By: ekartal5
bkelly2 wrote: |
Old code check, but I believe single wall vent not allowed in attic or concealed space
http://www.codecheck.com/pg21_22mechanical.html#flue |
Quote: |
The clearance to combustibles for Dura-Connect is one inch. It may not be used to pass through walls or ceilings, nor may it be placed in attics or crawl spaces. It may be used wherever single wall connector pipe is used. |
Quote: |
8.Ameri-Flex gas vent connector system is tested and
listed by UL for one inch (1?) clearance to combustibles in an unenclosed installation. Ameri- Flex vent pipe hangers (VPH) should be used at each end of a flexible length that is not attached to a fixed point, i.e. an appliance outlet. |
Originally Posted By: sradabaugh
Best Regards,
And Good Inspecting
Preferred Property Inspections
rray wrote: | ||
It is used quite often for our attic furnaces here, so apparently this specific stuff is approved for attics here. I wonder if there is a difference between an attic with appliances in it and an attic with no appliances in it. |
rray wrote: | ||
