Footer?
Originally Posted By: tallen
[ Image: http://www.nachi.org/bbsystem/usrimages/1/100_0946.JPG ]
[ Image: http://www.nachi.org/bbsystem/usrimages/1/100_0949.JPG ]
nachi.org/bbsystem/usrimages/1/100_0948.JPG ]
What do you all think?
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
Originally Posted By: gbeaumont
Hi Todd,
probably ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Looks like the home was added to and you have a classic case of differential settlement based on the first picture, I can't figure out the stain in the second pic, nor can I relate the 3rd pic to the others.
Regards
Gerry
Gerry Beaumont
NACHI Education Committee
e-mail : education@nachi.org
NACHI phone 484-429-5466
Inspection Depot Education
gbeaumont@inspectiondepot.com
"Education is a journey, not a destination"
Well. what happened is … They decided to add a closet to the Master bedroom. Problem is they added all that adobe block to patio slab. 3" ouch
The stains are off of splash blocks… Nothing to do with the structural problem…
I don't think so.
Originally Posted By: ahalstead
I always have problems interpreting photos posted on this board … at first glance i thought this was an addition built on top of a 4" slab with no footing or foundation. But it may be a full fledged foundation with a poly barrier under the stone? Not sure what i am seeing here . The difference in elevation between the old and new area of concrete is of no concern. However, i will bet the newer pour was never anchored into the existing. Shortly there will be differential settlement and cracking in that vertical joint between the old and the new. this should have been a caulked control joint rather than a mortared joint. The size of that bottom joint is horrendously large, obviously done to accomodate matching the bond of the original structure. I don’t see any flashing or weeps in the lowest mortar joint.
In photo #2 is there another control joint about 1.5 brick in from the corner? Appears to be a mortared control joint … perhaps this was a window or garage door opening at one time that is now bricked in … picture #2 seems to show brick which looks like the original brick of picture #1at the far side… perhaps the garage door was filled in to make another room? Pic #3 shows a crack from settling …
My guess, this is a garage door opening filled in with brick on top of the garage slab.
as i said, i always have a problem interpretting pictures .. always prefer to see it live ..
What is your exact question?
allen
It never should have been built… I don’t care what you do, you do not add 2500 lbs. to a 4" slab with no footings.
I called it as needs to be evaluated by a SE or a lic. Building contractor....
The agent was pissed ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
so my first suspiciaons were correct … it was built on top of an existing slab … you say a patio slab .
you are correct … you don’t build on top of that … and soon the owner will know why …
allen
oops
Gerry is my best freind LOL
Appears as if things are getting vicious in here … I am slowly slinking out the door … you boys have a good time …
ah
The third pic is the result of adding the extra weight to the 3-4’" slab.
I sometimes get called out to evaluate or approve additions and decks that were just built on old patios … can you say “underpinning” … I thought you could … icon_lol.gif
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
The Agent had “someone” go out to take a look.
Someone said That slab is fine.
I don't think so but someone does.
Just because it may not turn out to be a serious structural problem, doesn’t mean it isn’t a valid concern … there is a difference, and I think ya made the right call for further evaluation.
Just make sure your client gets a determination in writing from a licensed professional qualified to make that call ... ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Robert O'Connor, PE
Eagle Engineering ?
I talked to the client about it, and they said it had been taken care of. I asked them who had looked at it. They said their agent took care of it. I asked them if they had read my recommendation in the report about who should look at it, and they said yes.
I did what I could.
Thanks Robert.
Originally Posted By: five.five
any weep holes in the brick.
looks like moisture behind the brick is leaching out.
What did the roof look like, and what is behind that wall ? Pluming pipe ?
No weep holes
No moisture behind the adobe
Roof is 1 year old, still had to be recoated ![icon_rolleyes.gif](upload://iqxt7ABYC2TEBomNkCmZARIrQr6.gif)
A closet for the Master bedroom is behind the wall
