The length of the shanks of these nails protruding through the sheathing in the attic is much longer than the shank of any roofing nails I’ve ever seen. The roof itself was inaccessible due to snow and ice, so I couldn’t get up there to check if they were roofing or framing nails. The shanks look like framing nails. Has anyone ever heard of roofing nails this length?
I have seen roofing nails 3" long. The gauge of those look like roofing nails. When I lived up north I saw them looking like snowballs from poor ventilation and way too high humidity in the home. In one of you pics it looks like they are concentrated at the hip. It is normal for a roofer to use longer nails at the hip but that is longer than needed.:shock: I believe proper penetration is 1/4" through the deck. I hope you didn’t get stuck in the head.
I do not know if they are roofing nails. I can not see the ring tailed( racoon ) upper part and they are longer than 2.5 inch to me…
even for framing, the nails are not spiraled.
I rarely use common nails anymore. Every Article or component in framing system has a specific nail or fastener to use.
It is a shame the roof was completed that way…It is a safety issue.
Look roofing is the second easiest trade to accomplish. IE: meaning that I became a journeyman roofer after 2000 hours.
It attracts hard men in need or wanting of good money with the smallest of educational skills.
The easiest is demolition.
Framing nails are not galvanized, roofing nails are, so that’s one way to tell. Nails used for roofing should be corrosion-resistant. Framing nails are usually vinyl-coated sinkers. They may also be bright (no coating). If non-galvanized nails are used, the roof may fail prematurely and the manufacturer’s warranty is probably void.
…and unless a flush-nailing device was used, framing nails are more likely to have blasted most of the way through the shingles, reducing wind resistance even further.
Even there spacings or pattern ( nail ) are not orientated properly.
IE: meaning to where a properly nailed shingle nail would represent if it had been ( the over sized nail ) used instead of properly sized roofing nail. 1 1/4 to 1 1/2.
Make sense. Any comments?
It could also be that someone was trying to renail the deck and was a terrible shot and did not go into the attic to see all the shiners (too lazy??). There is no holding strength where the 2-3 nails are in between the deck boards anyway.
The distance seems too far from the hip to be cap nailing.
I miss the point about the deck.
My conclusion is the it might be a galvanized apron or some other furious or non forums metal because of excessive ice or snow buildup. http://www.design-technology.org/CDT10metalsproperties.htm
It is the work of the do-it-your-self person and has all the tell tale distinctive marking of someone that knows little about framing.
From wrong nails for the job to missing there intended mark.
