Inspected the garage and found the gas pipe for the water heater coming out of the wall, following around a door frame, and then going over to the water heater. I’ve reviewed my Code Check book and don’t see anything about copper pipe runs. My concern is that it runs around a commonly used door frame. Has anyone seen anything like this and is it allowable? Thanks for the feedback!
Hey guys, looking back through my photos I realize that the line is not for the water heater, but instead, comes from a junction behind the water heater and is being used to supply a gas stove. I think this would explain why the gas stove didn’t reach a fully developed flame when ignited. I suspect the supply line is too small. Thanks for all your feedback!
Hey Robert and Simon, unfortunately the copper line disappears into the wall. The gas cooktop is on the other side and I was unable to see the connection. I suspect a direct copper line is not allowed since I’ve never seen a direct copper connection to a gas stove/cooktop.
“NOTE: The gas supply to the stove was not immediate. When lighting the cooktop the flame would not fully develop for several seconds. There may be some issue with the gas supply lines, i.e., too small diameter pipe or improperly connected. Recommend evaluation by a licensed plumber.
NOTE: The supply line appears to be situated in a high traffic area that makes it susceptible to damage. Recommend evaluation by a licensed plumber.”
I believe this will cover it. Thanks Robert for the Inspectapedia link. I don’t know why I didn’t think of that along with the Code Check book. It’s been a long week.
That is a lot of 3/8 inch copper supply exposed gas piping. You will not find anywhere in the IPC or the UPC were that length of 3/8 inch copper gas piping is allowed.
