Originally Posted By: apightling
For those who might want to roll their own GFCI tester. . . . the following has worked for me:
Parts:
Clamshell 120VAC plug
Door bell push button that fits in the end of the receptacle without touching other conductors.
100K 1/2W resistor
25K 1/2W resistor . . . change this to 5K 1/2W per next post. . .
The door bell button goes where the electrical wire would have gone if it was used. . . . in the end of the clamshell plug opposite the prongs. . . you might have to trim some plastic.
Install the 100K in the receptacle from hot to neutral at the screw terminals of the plug. Connect the 5K from hot (blk, gold) to one side of the door bell switch. Connect the other side of the door bell switch to the ground connection in the plug.
Screw the assy together such that nothing is touching. . . yes it is a pain if your leads are too long. . . . rem: you can't cut em longer. . . .
Get out your handy Ohm meter. You should read 100KOhms from hot to neutral. You should read infinite from hot or neutral to ground.
When the button is pressed you should read 100K from hot to neutral, 105K from neutral to ground, and 5K from hot to ground. If you get these readings or something very close to them go to the next step. If not, find out where you miswired and fix it, and start this step over.
Plug your assy into a GFCI outlet. . .. nothing should happen . . . the 100K is dissipating about 0.144W so even enclosed in the plug it should last a long time if you left it plugged in . . . you wouldn't but . . . . if you did . . . . . . push the button . . . the GFCI should trip right away. Release the button and reset the GFCI . . . try it again . . . it works . . good . . .
Plugging the assy into a non GFCI outlet doesn't do much unless you have GFCI breakers on it . . . I haven't checked a GFCI breaker but the assy should trip them just fine . . .
Yeah, I know it should be approved by someone or other before use . . . I R an engineer . . . does that count? . . . 'never let the train run off the track while I was driving . . . . at any rate, no warranty for specific use is expressed or implied and if you build it you accept all responsibility for its use. . . . by whomever might use it now, in the future, or the past if time travel is invented.
If something needs more explanation please post here. . . if you have a question others probably do too . . .
-ap
