Originally Posted By: jpope
On my morning inspection today, my “three light outlet tester” showed reverse polarity in a GFCI outlet located in the garage. I noted this in my report and moved on.
Further into the inspection, I plugged into another GFCI outlet, pushed the test button on my tester, the GFCI tripped, I pushed the reset button on the outlet and when it powered back up, my tester showed reverse polarity
The test button on my tester would not trip the GFCI while it was indicating reverse polarity. I pushed the test button on the outlet and then reset it. It powered up and my tester showed a normal status.
I tripped it again with my tester and when it was reset, it was reversed again.
For whatever reason, every time I tripped the GFCI with my tester, the outlet would show reversed polarity when it was reset.
Needless to say, I reset the GFCI and left it alone. Perplexed, I went back to the garage GFCI and pushed the test button on the outlet. When I reset it, it show all systems normal.
Without telling me to throw away my "three light testers," can someone explain this?
Jeff Pope
JPI Home Inspection Service
(661) 212-0738
