Glossary
Originally Posted By: Walter Engelking
I noticed a listing for “sheetrock”. I believe that is a brand name of drywall, and as such should not be listed, at least not without a brand name notation.
Walter Engelking
Originally Posted By: gsutterfield
Sheet-rock: " A trademark for plasterboard " icon_wink.gif
Originally Posted By: mjones1
- 43,560 square feet.
A/C Circuit - (Alternating Current) The flow of current through a conductor first in one direction then in reverse. It is used exclusively in residential and commercial wiring because it provides greater flexibility in voltage selection and simplicity of equipment design.
Accelerator - Any material added to stucco, plaster or mortar which speeds up the natural set.
Adhesion - The property of a coating or sealant to bond to the surface to which it is applied.
Adhesive Failure - Loss of bond of a coating or sealant from the surface to which it is applied.
Aggregate - Crushed stone, slag or water-worn gravel that comes in a wide range of sizes that is used to surface built-up roofs.
Air-Dried Lumber - Lumber that has been piled in yards or sheds for any length of time. For the United States as a whole, the minimum moisture content of thoroughly air dried lumber is 12 to 15 percent and the average is somewhat higher. In the South, air dried lumber may be no lower than 19 percent.
Air Duct - Ducts, usually made of sheet metal, that carry cooled or heated air to all rooms.
Air Infiltration - The amount of air leaking in and out of a building through cracks in walls, windows and doors.
Airway - A space between roof insulation and roof boards for movement of air.
Alligatoring - A condition of paint or aged asphalt brought about by the loss of volatile oils and the oxidation caused by solar radiation. Coarse checking pattern characterized by a slipping of the new paint coating over the old coating to the extent that the old coating can be seen through the fissures. "Alligatoring" produces a pattern of cracks resembling an alligator hide and is ultimately the result of the limited tolerance of paint or asphalt to thermal expansion or contraction.
Anchor Bolts - In residential construction, Bolts to secure a wooden sill plate to concrete, or masonry floor or wall. In commercial construction, bolts which fasten columns, girders or other members to concrete or masonry such as bolts used to anchor sills to masonry foundation.
Areaway - An open subsurface space adjacent to a building used to admit light or air or as a means of access to a basement.
Astragal - A molding, attached to one of a pair of swinging doors, against which the other door strikes.
Attic Ventilators - In houses, screened opening) provided to ventilate an attic space. They are located in the soffit area as inlet ventilators and in the gable end or along the ridge as outlet ventilators. They can also consist of power-driven fans used as an exhaust system.
Auger - In carpentry, a wood-boring tool used by a carpenter to bore holes.
ABS (Acrylonitrile butadiene styrene)
Rigid black plastic pipe used only for drain lines.
Access Panel- An opening in the wall or ceiling near the fixture that allows access for servicing the plumbing/electrical system.
Adaptor- A fitting that unites different types of pipe together, e.g. ABS to cast iron pipe.
Actual Dimension (lumber) - The exact measurement of lumber after it has been cut, dried and milled.
Air Chamber - A vertical, air filled pipe that prevents water hammer by absorbing pressure when water is shut off at a faucet or valve.
Algae - Microorganisms that may grow to colonies in damp environments, including certain rooftops. They can discolor shingles. Often described as "fungus."
Allowable Span - The distance between two supporting points for load bearing lumber such as joist, rafters or a girder.
Allowance(s) - A sum of money set aside in the construction contract for items which have not been selected and specified in the construction contract. Best kept to a minimum number and used for items who's choice will not impact earlier stages of the construction. For example, selection of tile as flooring may require an alternative framing or underlayment material. (Also money that your parents give you as a child)
Ampacity - Refers to the how much current a wire can safely carry. For example, a 12 gauge electrical copper wire can safely carry up to 20 amps
APA Plywood - (APA=American Plywood Association) Plywood that has been rated by the American Plywood Association. For example, number one APA rated exterior plywood, contains no voids between laminate layers.
Acrylic - A glassy, thermoplastic material that is vacuum-formed to cast and mold shapes that form the surface of fiberglass bathtubs, whirlpools, shower bases, and shower stalls.
Aerator - An apparatus that mixes air into flowing water. It is screwed onto the end of a faucet spout to help reduce splashing.
Angle stop - A shutoff valve in which the inlet connects to the water supply pipe in the wall and the outlet angles 90 degrees upward toward the faucet or toilet.
Anti-scald - A valve that restricts water flow to help prevent burn injuries. See pressure balancing valve and thermostatic valve. In some areas, plumbing codes require anti-scald valves. Speak to a professional in your area for more information and help with code requirements.
Anti-siphon - A device that prevents waste water from being drawn back into supply lines, possibly contaminating the water supply. See backflow preventer.
Asbestos - (1) A common form of magnesium silicate which was used in various construction products due to it's stability and resistance to fire. Asbestos exposure by inhaling loose asbestos fibers is associated with various forms of lung disease. (2) The name given to certain inorganic minerals when they occur in fibrous form. Though fire-resistant, it?s extremely fine fibers are easily inhaled, and exposure to them over a period of years has been linked to cancers of the lung or lung-cavity lining and to asbestosis a severe lung impairment.
Asphalt plastic cement - An asphalt-based cement used to bond roofing materials.
AAMA ? Architectural Aluminum Manufacturer?s Association.
Above- grade ? The portion of a building that is above ground level.
Air duct ? Ducts, usually made of sheet metal, that carry cooled air to all rooms.
Air infiltration? The amount of air leaking in and out of a building through cracks in walls, windows and doors.
Air filters- Adhesive filters made of metal or various fibers that are coated with adhesive liquid to which the particles of lint and dust adhere. These filters will remove as much as 90% of the dirt if they do not become clogged. The more common filters are of the throwaway or disposable type.
Aluminum wire - Conductors made of aluminum for carrying electricity. Aluminum generally is limited to the larger wire sizes. Due to its lower conductivity, aluminum wire smaller than No. 12 is not made. Aluminum is lighter and less expensive than copper but not as good a conductor. It also breaks easily.
Amps (AMPERES) - The rate at which electricity flows through a conductor.
Ammeter - Device to measure the current flowing in a circuit.
Anchor bolts - Bolts which fasten columns, girders or other members to concrete or masonry such as bolts used to anchor sills to masonry foundation.
Angle iron ? A piece of iron that forms a right angle and is used to span openings and support masonry at the openings. In brick veneer, they are used to secure the veneer to the foundation. Also known as shelf angle.
Annealing ? In the manufacturing of float glass, it is the process of controlled cooling done in a Lahr to prevent residual stresses in the glass. Re-annealing is the process of removing objectionable stresses in glass by re-heating to a suitable temperature followed by controlled cooling.
Anti-walk blocks ? Elastomeric blocks that limit lateral glass movement in the glazing channel which may result from thermal, seismic, wind load effects, building movement, and other forces that may apply.
Approach- The area between the sidewalk and the street that leads to a driveway or the transition from the street as you approach a driveway.
Architect - A tradesman who designs and produces plans for buildings, often overseeing the building process.
Architects rule (ruler) - Three sided ruler with different scales on each side. Also referred to as a "scale."
Asphalt - A dark brown to black, highly viscous, hydrocarbon produced from the residue left after the distillation of petroleum. Asphalt is used on roofs and highways as a waterproofing agent.
A/C- An abbreviation for air conditioner or air conditioning.
A/C Condenser- The outside fan unit of the Air Conditioning system. It removes the heat from the Freon gas and "turns" the gas back into a liquid and pumps the liquid back to the coil in the furnace.
A/C Disconnect- The main electrical ON-OFF switch near the A/C Condenser.
Air space - The area between insulation facing and interior of exterior wall coverings. Normally a 1" air gap.
Amortization - A payment plan by which a loan is reduced through monthly payments of principal and interest.
Annual Percentage Rate (APR)- Annual cost of credit over the life of a loan, including interest, service charges, points, loan fees, mortgage insurance, and other items.
Appraisal- An expert valuation of property.
Apron- A trim board that is installed beneath a window sill.
Area wells- Corrugated metal or concrete barrier walls installed around a basement window to hold back the earth.
Assessment - A tax levied on a property, or a value placed on the worth of a property.
Attic access- An opening that is placed in the drywalled ceiling of a home providing access to the attic.
Mike
Originally Posted By: Blaine Wiley
The unstoppable urge to moo when driving past a herd of cattle. MOOOOO
or this
Hicsnort The disastrous and embarrassing act of a previously ingested beverage exiting the nose during extreme laughter.
- Anything you can’t remember the name for.
![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Mike
"Acre - 43,500 square feet. "
43,560 sq. ft.
Mike P.
- In glazing, a polyethylene or polyurethane foam material installed under compression and used to control sealant joint depth, provide a surface for sealant tooling, serve as a bond breaker to prevent three-sided adhesion, and provide an hour-glass contour of the finished bead.
Backfill - (1) filling in any previously excavated area, i.e., The replacement of excavated earth into a trench around and against a basement foundation.. (2) in carpentry, the process of fastening together two pieces of board by gluing blocks of wood in the interior angle.
Backflow- The flow of liquids through irrigation into the pipes of a potable or drinking water supply from any source which is opposite to the intended direction of flow.
Backflow Preventer - A device or means to prevent backflow into the potable water supply.
Backhand - A simple molding sometimes used around the outer edge of plain rectangular casing as a decorative feature.
Backhoe - Self-powered excavation equipment that digs by pulling a boom mounted bucket towards itself. It is used to dig basements and/or footings and to install drainage or sewer systems.
Back Nailing - The practice of nailing roofing felts to the deck under the overlap, in addition to hot mopping, to prevent slippage of felts.
Balloon Framing - In carpentry, the lightest and most economical form of construction, in which the studding and corner plates are set up in continuous lengths from the first floor line or sill to the roof plate to which all floor joists are fastened.
Balusters - Usually small vertical members in a railing used between a top rail and the stair treads or a bottom rail.
Balustrade - A railing made up of balusters, top rail, and sometimes bottom rail, used on the edge of stairs, teal conies, and porches.
Barge Board - A decorative board covering the projecting rafter (fly rafter) of the gable end. At the cornice, this member is a facie board.
Base (or Baseboard) - A board placed against the wall around a room next to the floor to finish properly between floor and plaster.
Barometer - Instrument for measuring atmospheric pressure.
Barrel Roof - A roof design, which in cross section is arched.
Base Flashing - The upturned edge of the watertight membrane formed at a roof termination point by the extension of the felts vertically over the cant strip and up the wall for a varying distance where they are secured with mechanical fasteners.
Base Molding - Molding used to trim the upper edge of interior baseboard.
Base Ply - An asphalt-saturated and/or coated felt installed as the first ply with 4 inch laps in a built-up roof system under the following felts which can be installed in a shingle-like fashion.
Base Shoe - Molding used next to the floor on interior base board. Sometimes called a carpet strip.
Batten - Narrow strips of wood used to cover joints or as decorative vertical members over plywood or wide boards.
Batten Plate - A formed piece of metal designed to cover the joint between two lengths of metal edge.
Batter Board - One of a pair of horizontal boards nailed to posts set at the corners of an excavation, used to indicate the desired level, also as a fastening for stretched strings to indicate outlines of foundation walls.
Batt Insulation- Strips of insulation, usually fiberglass that fit between studs or other framing.
Bay Window - Any window space projecting outward from the walls of a building, either square or polygonal in plan.
Bead - In glazing, an applied sealant in a joint irrespective of the method of application, such as caulking bead, glazing bead, etc. Also a molding or stop used to hold glass or panels in position.
Beam - Structural support member (steel, concrete, lumber) transversely supporting a load that transfers weight from one location to another.
Bearing Partition - A partition that supports any vertical load in addition to its own weight.
Bearing Wall - A wall that supports any vertical load in addition to its own weight.
Bed or Bedding - In glazing, the bead compound or sealant applied between a light of glass or panel and the stationary stop or sight bar of the sash or frame. It is usually the first bead of compound or sealant to be applied when setting glass or panels.
Bed Molding - A molding in an angle, as between the over hanging cornice, or eaves, of a building and the side walls.
Bell Reducer - In plumbing, a fitting shaped like a bell which has one opening of a smaller diameter used to reduce the size of the pipe in the line, and the opposite opening of larger diameter.
Below Grade - The portion of a building that is below ground level.
Bent Glass - Flat glass that has been shaped while hot into curved shapes.
Bevel - The angle of the front edge of a door usually from 1/8" to 2".
Bevel Siding (or Lap Siding) - Wedge-shaped boards used as horizontal siding in a lapped pattern. This siding varies in butt thickness from ? to ? inch and in widths up to 12 inches. Normally used over some type of sheathing.
Bid Documents - Drawings, details, and specifications for a particular project.
Bite - The dimension by which the framing system overlaps the edge of the glazing infill.
Bitumen - Any of various mixtures of hydrocarbons occurring naturally or obtained through the distillation of coal or petroleum. (See Coat Tar Pitch and Asphalt)
Bleeding - A migration of a liquid to the surface of a component or into/onto an adjacent material.
Blind Nailing - Nailing in such a way that the nail heads are not visible on the face of the work?usually at the tongue of matched boards.
Blind Stop - A rectangular molding, usually ? by 1-3/8 inches or more in width, used in the assembly of a window frame. Serves as a stop for storm and screen or combination windows and to resist air infiltration.
Blister - An enclosed raised spot evident on the surface of a building. They are mainly caused by the expansion of trapped air, water vapor, moisture or other gases.
Blocking - In carpentry, the process of fastening together two pieces of board by gluing blocks of wood in the interior angle.
Blue Prints- Architectural plans for a building or construction project, which are likely to include floor plans, footing and foundation plans, elevations, plot plans, and various schedules and or details.
Blue Stain - A bluish or grayish discoloration of the sapwood caused the growth of certain mold like fungi on the surface and in the interior of a piece, made possible by the same conditions that favor the growth of other fungi.
Boards - Yard lumber less than 2 inches thick and 2 or more inches wide.
Bodied Linseed Oil - Linseed oil that has been thickened in viscosity by suitable processing with heat or chemicals. Bodied oils are obtainable in a great range in viscosity from a little greater than that of raw oil to just short of a jellied condition.
Boiled Linseed Oil - Linseed oil in which enough lead, manganese or cobalt salts have been incorporated to make the oil harden more rapidly when spread in thin coatings.
Bolster - A short horizontal timber or steel beam on top of a column to support and decrease the span of beams or girders.
Bond Breaker - A substance or a tape applied between two adjoining materials to prevent adhesion between them.
Bond Plaster - In addition to gypsum, bond plaster contains 2-5% lime by weight and chemical additives which improve the bond with dense non-porous surfaces such as concrete. It is used as a base coat.
Boston Ridge - A method of applying asphalt or wood shingles at the ridge or at the hips of a roof as a finish.
Bow - A curve, bend, warping or other deviation from flatness in glass or wood.
Brace - An inclined piece of framing lumber applied to wall or floor to stifled the structure. Often used on walls as temporary bracing until framing has been completed.
Bracing - Ties and rods used for supporting and strengthening various parts of a building used for lateral stability for columns and beams.
Brake Metal - Sheet metal that has been bent to the desired configuration.
Brick Veneer - A facing of brick laid against and fastened to sheathing of a frame wall or tile wall construction.
Bridging - Small wood or metal members that are inserted in a diagonal position between the floor joists at midspan to act both as tension and compression members for the purpose of bracing the joists a spreading the action of loads.
Browncoat - The coat of plaster directly beneath the finish coat. In three-coat work, the brown is the second coat.
BTU - British Thermal Unit - The amount of heat energy required to raise the temperature of one pound of water through a change of one degree F.
Bubbling - In glazing, open or closed pockets in a sealant caused by release, production or expansion of gasses.
Buck - Often used in reference to rough frame opening members. Door bucks used in reference to metal door frame.
Building Brick - Brick for building purposes not especially treated for texture or color, formerly called "common brick." It is stronger than face brick.
Building Permit - Written authorization from the city, county or other governing regulatory body giving permission to construct or renovate a building. A building permit is specific to the building project described in the application.
Built-Up Roof - A roofing composed of three to five layers of asphalt felt laminated with coal tar, pitch, or asphalt. The top is finished with crushed slag or gravel. Generally used on flat or low-pitched roofs.
Bullfloat - A tool used to finish and flatten a slab. After screeding, the first stage in the final finish of concrete, smoothes and levels hills and voids left after screeding. Sometimes substituted for darbying. A large flat or tool usually of wood, aluminum or magnesium with a handle.
Butt Joint - The junction where the ends of two timbers or other members meet in a square-cut joint.
Butterfly Roof - A roof assembly, which pitches sharply from either side toward the center.
Buttering - In glazing, application of sealant or compound to the flat surface of some member before placing the member in position, such as the buttering of a removable stop before fastening the stop in place.
Butt Glazing - The installation of glass products where the vertical glass edges are without structural supporting mullions.
Butyl - Type of non-curing and non-skinning sealant made from butylene. Usually used for internal applications.
BX - Armored Cable - A factory assembly of insulated conductors inside a flexible metallic covering. It can be run except where exposed to excessive moisture and should not be run below grade. It must always be grounded and uses its armor as an equipment ground. It is difficult to pull out old wires or insert new ones.
Ballcock - A toilet tank water supply valve which is controlled by a float ball.
Batter Boards - Temporary structures that hold strings used to locate and square the corners of a building.
Beam - A horizontal framing member designed to carry a load from a set of joists or a roof and spanning an open space. Usually 6" x 6" or 4" x 10" or larger.
Bird's-Mouth Cut - A cutout in a rafter where it crosses the top plate of the wall providing a bearing surface for nailing. Also called a heel cut.
Bitumen - Term commonly applied to various mixtures of naturally occurring solid or liquid hydrocarbons, excluding coal. These substances are described as bituminous. Asphalt is a bitumen.
Blue Print(s) - A type of copying method often used for architectural drawings. Usually used to describe the drawing of a structure which is prepared by an architect or designer for the purpose of design and planning, estimating, securing permits and actual construction.
Board and batten - A method of siding in which the joints between vertically placed boards or plywood are covered by narrow strips of wood.
Board foot - The volume of a piece of wood measuring 12 inches square and in inch thick. A piece of lumber 1/2" thick and 6 inches wide and 24 inches long is equal to one board foot.
Bonding Strip (Electrical) - A thin strip of metal inside armored or BX cable. This strip is meant to back up the primary ground.
Box Cornice - A cornice completely closed with trim work.
Branch Circuit (Electrical) - Wiring that runs from a service panel or sub-panel to outlets. Branch circuits are protected by fuses or breakers at the panel.
Bridging - Wood blocks installed in an X fashion between floor joist to stabilize and position the joist.
Built-up beam (or girder) - Beam (or girder) created by sistering or "scabbing" two or more pieces of lumber together.
Built-up roof - A type of commercial, or "flat" roof finish, produced by applying alternate layers of roofing felt and hot asphalt or pitch. The top layer is given a hot flood coat of the bitumen; granules of rock, gravel, slag, or ceramic particles may be embedded while the flood coat is still hot. The roofing system may incorporate rigid insulation.
Butt Joint - Lumber pieces joined at the ends.
Bundle - A package of shingles. There are 3, 4 or 5 bundles per square.
Butt edge - The lower edge of the shingle tabs.
Backsplash - A raised integral portion of a wall mount sink or lavatory located at the rear to protect the wall.
Basket strainer - Basket shaped strainer with holes allowing water to drain while catching food or other solids. Can also be closed to fill the sink with water.
Bushing - A pipe fitting for joining pipes with different diameters. A bushing is threaded on the inside and outside.
Back Charge- Billings for work performed or costs incurred by one party that, in accordance with the agreement, should have been performed or incurred by the party to whom billed. Owners bill back charges to general contractors, and general contractors bill back charges to subcontractors. Examples of back charges include charges for cleanup work or to repair something damaged by another subcontractor, such as a tub chip or broken window.
Backing- Frame lumber installed between the wall studs to give additional support for drywall or an interior trim related item, such as handrail brackets, cabinets, and towel bars. In this way, items are screwed and mounted into solid wood rather than weak drywall that may allow the item to break loose from the wall. Carpet backing holds the pile fabric in place.
Backout- Work the framing contractor does after the mechanical subcontractors (Heating-Plumbing-Electrical) finish their phase of work at the Rough (before insulation) stage to get the home ready for a municipal frame inspection. Generally, the framing contractor repairs anything disturbed by others and completes all framing necessary to pass a Rough Frame Inspection.
Ballast- A transformer that steps up the voltage in a florescent lamp.
Barge- Horizontal beam rafter that supports shorter rafters.
Basement window inserts- The window frame and glass unit that is installed in the window buck.
Base shoe- Molding used next to the floor on interior base board. Sometimes called a carpet strip.
Bat - A half-brick.
Bearing point- A point where a bearing or structural weight is concentrated and transferred to the foundation
Bearing header- (a) A beam placed perpendicular to joists and to which joists are nailed in framing for a chimney, stairway, or other opening. (b) A wood lintel. (c) The horizontal structural member over an opening (for example over a door or window).
Bedrock- A subsurface layer of earth that is suitable to support a structure.
Bid- A formal offer by a contractor, in accordance with specifications for a project, to do all or a phase of the work at a certain price in accordance with the terms and conditions stated in the offer.
Bid bond- A bond issued by a surety on behalf of a contractor that provides assurance to the recipient of the contractor's bid that, if the bid is accepted, the contractor will execute a contract and provide a performance bond. Under the bond, the surety is obligated to pay the recipient of the bid the difference between the contractor's bid and the bid of the next lowest responsible bidder if the bid is accepted and the contractor fails to execute a contract or to provide a performance bond.
Bid security Funds or a bid bond submitted with a bid as a guarantee to the recipient of the bid that the contractor, if awarded the contract, will execute the contract in accordance with the bidding requirements of the contract documents.
Bid shopping- A practice by which contractors, both before and after their bids are submitted, attempt to obtain prices from potential subcontractors and material suppliers that are lower than the contractors' original estimates on which their bids are based, or after a contract is awarded, seek to induce subcontractors to reduce the subcontract price included in the bid.
Bidding requirements- The procedures and conditions for the submission of bids. The requirements are included ion documents, such as the notice to bidders, advertisements for bids, instructions to bidders, invitations to bid, and sample bid forms.
Bifold door- Doors that are hinged in the middle for opening in a smaller area than standard swing doors. Often used for closet doors.
Binder- A receipt for a deposit to secure the right to purchase a home at an agreed terms by a buyer and seller.
Bipass doors- Doors that slide by each other and commonly used as closet doors.
Blankets- Fiber-glass or rock-wool insulation that comes in long rolls 15 or 23 inches wide.
Blocked (door blocking)- Wood shims used between the door frame and the vertical structural wall framing members.
Blocked (rafters)- Short "2 by 4's" used to keep rafters from twisting, and installed at the ends and at mid-span.
Block out- To install a box or barrier within a foundation wall to prevent the concrete from entering an area. For example, foundation walls are sometimes "blocked" in order for mechanical pipes to pass through the wall, to install a crawl space door, and to depress the concrete at a garage door location.
Blow insulation- Fiber insulation in loose form and used to insulate attics and existing walls where framing members are not exposed.
Blue stake- Another phrase for Utility Notification. This is when a utility company (telephone, gas, electric, cable TV, sewer and water, etc) comes to the job site and locates and spray paints the ground and/or installs little flags to show where their service is located underground.
Board foot- A unit of measure for lumber equal to 1 inch thick by 12 inches wide by 12 inches long. Examples: 1" x 12" x 16' = 16 board feet, 2" x 12" x 16' = 32 board feet
Bond or bonding - An amount of money (usually $5,000-$10,000) which must be on deposit with a governmental agency in order to secure a contractor's license. The bond may be used to pay for the unpaid bills or disputed work of the contractor. Not to be confused with a 'performance bond'. Such bonds are rarely used in residential construction, they are an insurance policy which guarantees proper completion of a project.
Boom- A truck used to hoist heavy material up and into place. To put trusses on a home or to set a heavy beam into place.
Bottom chord - The lower or bottom horizontal member of a truss.
Bottom plate- The "2 by 4's or 6's" that lay on the subfloor upon which the vertical studs are installed. Also called the 'sole plate'.
Brace- An inclined piece of framing lumber applied to wall or floor to strengthen the structure. Often used on walls as temporary bracing until framing has been completed.
Breaker panel- The electrical box that distributes electric power entering the home to each branch circuit (each plug and switch) and composed of circuit breakers.
Brick ledge- Part of the foundation wall where brick (veneer) will rest.
Brick lintel- The metal angle iron that brick rests on, especially above a window, door, or other opening.
Brick mold-Trim used around an exterior door jamb that siding butts to.
Brick tie- A small, corrugated metal strip @ 1" X 6"- 8" long nailed to wall sheeting or studs. They are inserted into the grout mortar joint of the veneer brick, and holds the veneer wall to the sheeted wall behind it.
Brick veneer- A vertical facing of brick laid against and fastened to sheathing of a framed wall or tile wall construction.
Builder's Risk Insurance- Insurance coverage on a construction project during construction, including extended coverage that may be added for the contract for the customer's protections.
Building codes- Community ordinances governing the manner in which a home may be constructed or modified.
Building paper- A general term for papers, felts, and similar sheet materials used in buildings without reference to their properties or uses. Generally comes in long rolls.
Bull nose (drywall)- Rounded drywall corners.
Bundle - A package of shingles. Normally, there are 3 bundles per square and 27 shingles per bundle.
Butt edge- The lower edge of the shingle tabs.
Butt hinge- The most common type. One leaf attaches to the door's edge, the other to its jamb.
Buy down- A subsidy (usually paid by a builder or developer) to reduce monthly payments on a mortgage.
By fold door- Doors that are hinged in the middle for opening in a smaller area than standard swing doors. Often used for closet doors.
By pass doors- Doors that slide by each other and commonly used as closet doors.
Mike
Originally Posted By: Nick Gromicko
Mike:
I'm ready for C's.
Nick
Originally Posted By: dvalley
A structural member which projects beyond its supporting column or wall, and supports a load.
CARPENTER ANTSAnts that bore through wood. Like termites, carpenter ants like warm, moist areas such as those found in wood structures in this part of the country. Carpenter ants differ from termites in several important ways. Carpenter ants do not ingest the wood; rather, they tunnel through the wood leaving a residue of sawdust. Also differing from termites, carpenter ants can nest anywhere; it is not uncommon to find a carpenter ant nest in an attic. Carpenter ants can do a great amount of structural damage.
CASING Window and door framing.
CAULKING A flexible putty-like compound used to fill gaps between windows, doors, trim, etc., and the structure they are mounted in. Caulking helps prevent air and water infiltration.
CAVITY WALL A hollow wall section created by wood framing members and usually insulated.
CERTIFICATE OF TITLE Issued by a title company. Indicates that the seller has good marketable and insurable title to the property he/she is offering for sale.
CESPOOL An underground catch basin for liquid waste, usually lined with brick, concrete, or stone, capable of drainage into the surrounding soil.
CHIMNEY CAP A concrete cover at the top of a brick chimney
CLAPBOARD Wood exterior siding that is thicker on one edge than the other. Comes in a variety of lengths. It is overlapped and nailed into sheathing.
CLOSING COSTS A number of expenses associated with completing the transaction in the transfer of ownership of real estate including attorney’s fee, partial heating, electric and tax bill, etc.
CLOSING DAY Day on which seller and buyer meet to conclude formalities of real estate sale.
COCKLOFT The air space between the underside of a flat roof and the top floor ceiling.
COMMISSION Money paid to real estate broker by the seller for facilitating the sale of the property.
COLLAR BEAM Wood beam connecting two inclined roof rafters. It helps to stiffen the framing of a pitched roof structure.
COLUMN In architecture, a perpendicular supporting member, circular or rectangular in section, usually consisting of a base, shaft, and capitals. In engineering, a vertical structural compression member which supports loads acting in the direction of its longitudinal axis.
COPING A tile cap used to cover the top of a parapet wall or any regular masonry wall.
CONCRETE A mixture of Portland cement, sand, gravel, and water used in building construction for foundation walls, floor slabs, footings, etc.
CONDUCTOR Material used to transmit an electric current, such as copper wire.
COPALUM CONNECTOR A special type of crimp connector the US Consumer Product Safety Commission recommends when pigtailing Copper wires to Aluminum wiring.
CORNICE Wood or metal decorative projection at the roof level of a building. It usually projects outward and is located at the front of the building.
COUNTER FLASHING Sheet metal placed at the base of a parapet wall over the roof covering, or at the base of a chimney, to prevent water entry.
CRIPPLE STUDS Short wood members used above and below window and door openings to support frame.
David Valley
MAB Member
http://www.masscertified.com
- A chemical used to speed up curing of concrete during damp conditions.
Canopy - An overhanging roof.
Cant Strip - A beveled support used at the junction of a flat surface and a vertical surface to prevent bends and/or cracking of the roofing membrane at the intersection of the roof deck and wall. Used with a base flashing to minimize breaking of the roofing felts.
Cap Sheets - In roofing, one to four plies of felt bonded and top coated with bitumen that is laid over an existing roof as a treatment for defective roofs.
Cape Chisel - Tool used to clean out mortar joints on brick.
Casement Frames and Sash - Frames of wood or metal enclosing part or all of the sash, which may be opened by means of hinges affixed to the vertical edges.
Casing - Molding of various widths and thicknesses used to trim door and window openings at the jambs.
Cellulose Insulation - Ground up newspaper that is treated with a fire retardant.
Cement Mixtures - Rich - 1 part cement, 2 parts sand, 3 parts coarse aggregate. Used for concrete roads and waterproof structures. Standard - 1 part cement, 2 parts sand, 4 parts coarse aggregate. Used for reinforced work floors, roofs, columns, arches, tanks, sewers, conduits, etc. Medium - 1 part cement, 2 1/2 parts sand, 5 parts coarse aggregate. Used for foundations, walls, abutments, piers, etc. Lean - 1 part cement, 3 parts sand, 6 parts coarse aggregate. Used for all mass concrete work, large foundations, backing for stone masonry, etc. Mixtures are always listed Cement to Sand to Aggregate
Cement Types - Type I Normal - is a general purpose cement suitable for practically all uses in residential construction but should not be used where it will be in contact with high sulfate soils or be subject to excessive temperatures during curing. Type II Moderate is used where precaution against moderate sulfate attack is important, as in drainage structures where sulfate concentrations in groundwater's are higher than normal. Type III High Early Strength is used when high strengths are desired at very early periods, usually a week or less. It is used when it is desirable to remove forms as soon as possible or to put the concrete into service quickly. Type IV Low Heat is a special cement for use where the amount and rate of heat generated during curing must be kept to a minimum. The development of strength is slow and is intended in large masses of concrete such as dams. Type V Sulfate Resisting is a special cement intended for use only in construction exposed to severe sulfate action, such as western states having soils of high alkali content.
Certificate of Occupancy - A document stating that a building is approved for occupancy. The building authority issues the Certificate of Occupancy.
CFM (Cubic Feet per Minute) - The measure of volume of air. When testing systems, find the CFM by multiplying the face velocity times the free area in square feet. The face velocity is the amount of air passing through the face of an outlet or return. Free area is the total area of the openings in the outlet or inlet through which air can pass.
Chair Rail - A molding that runs horizontally along the wall at about 3 feet from the ground. In storefront, window wall, or curtain wall systems, a chair rail is an aluminum extrusion applied horizontally to the inside of the system 3 feet from the floor to create a barrier in floor-to-ceiling glazing applications.
Channel Glazing - The installation of glass products into U-shaped glazing channels. The channels may have fixed stops; however, at least one glazing stop on one edge must be removable.
Checking - Fissures that appear with age in many exterior paint coatings, at first superficial, but which in time may penetrate entirely through the coating. It produces a pattern of surface cracks running in irregular lines. When found in the top pour of an asphalt built-up roof, checking is the preliminary stage of alligatoring.
Checkrails - Meeting rails sufficiently thicker than a window to fill the opening between the top and bottom sash made by the parting stop in the frame of double-hung windows. They are usually beveled.
Chemical Injection Grouting ? Leak repair technique usually used below grade in cracks and joints in concrete walls and floors that involves injection of sealant (usually urethane) that reacts with water to form a seal.
Cleat - A wedge-shaped piece (usually of metal) which serves as a support or check. A strip fastened across something to give strength or hold something in position.
Coal Tar Pitch - A bituminous material, which is a by-product from the coking of coal. It is used as the waterproofing material for tar and gravel built-up roofing.
Cohesive Failure - Internal splitting of a compound resulting from over-stressing of the compound.
Cold Applied - Products that can be applied without heating. These are in contrast to products which need to be heated to be applied.
Cold Patch - In roofing, a roof repair done with cold-applied material.
Collar - In roofing, a conical metal cap flashing used in conjunction with vent pipes or stacks usually located several inches above the plane of the roof, for the purpose of shedding water away from the base of the vent.
Collar Beam - In carpentry, a tie that keeps the roof from spreading. They serve to stiffen the roof structure. Connects similar rafters on opposite sides of roof.
Column - In architecture: A perpendicular supporting member, circular or rectangular in section, usually consisting of a base, shaft, and capital. In engineering: A vertical structural compression member which supports loads acting in the direction of its longitudinal axis.
Combination Doors or Windows - Combination doors or windows used over regular openings. They provide winter insulation and summer protection and often have self storing or removable glass and screen inserts. This eliminates the need for handling a different unit each season.
Compatible - Two or more substances, which can be mixed or blended without separating, reacting, or affecting either material adversely.
Component - Any one part of an assembly associated with construction.
Composite Board - An insulation board, which has two different insulation types laminated together in 2 or 3 layers.
Compression Gasket - A gasket designed to function under compression.
Compression Set - The permanent deformation of a material after removal of the compressive stress.
Concrete Plain - Concrete either without reinforcement, or reinforced only for shrinkage or temperature changes.
Condensation - The appearance of moisture (water vapor) on the surface of an object caused by warm moist air coming into contact with a colder object. In a building: Beads or drops of water (and frequently frost in extremely cold weather) that accumulate on the inside of the exterior covering of a building when warm, moisture-laden air from the interior reaches a point where the temperature no longer permits the air to sustain the moisture it holds. Use of louvers or attic ventilators will reduce moisture condensation in attics. A vapor barrier under the gypsum lath or dry wall on exposed walls will reduce condensation in them.
Conductor - (1) In roofing, a pipe for conveying rainwater from the roof gutter to a drain, or from a roof drain to the storm drain; also called a leader, downspout, or downpipe. (2) In electrical contracting, a wire through which a current of electricity flows, better known as an electric wire.
Conduction - The flow of heat from one part of a substance to another part. A piece of iron with one end placed in a fire will soon become warm from end to end, from the transfer of heat by the actual collision of the air molecules.
Conduit - A pipe, usually metal, for protecting and routing electrical wiring.
Construction, frame - A type of construction in which the structural parts are wood or depend upon a wood frame for support. In codes, if masonry veneer is applied to the exterior walls, the classification of this type of construction is usually unchanged.
Construction loan- A loan provided by a lending institution specifically to construct or renovate a building.
Control Joint - A control joint controls or accommodates movement in the surface component of a roof.
Convection - A method of transferring heat by the actual movement of heated molecules, usually by a freestanding unit such as a furnace.
Cooling Tower - A large device mounted on roofs, consisting of many baffles over which water is pumped in order to reduce its temperature.
Coping - A construction unit placed at the top of the parapet wall to serve as a cover for the wall.
Copper Pipe Types - Type K has the heaviest or thickest wall and is generally used underground. It has a green stripe. Type L has a medium wall thickness and is most commonly used for water service and for general interior water piping. It has a blue stripe. Type M has a thin wall and many codes permit its use in general water piping installation. It has a red stripe.
Corbel Out - To build out one or more courses of brick or stone from the face of a wall, to form a support for timbers.
Core - A small section cut from any material to show internal composition.
Corner Bead - A strip of formed sheet metal, sometimes combined with a strip of metal lath, placed on corners before plastering to reinforce them. Also, a strip of wood finish three-quarters-round or angular placed over a plastered corner for protection.
Corner Boards - Used as trim for the external corners of a house or other frame structure against which the ends of the siding are finished.
Corner Braces - Diagonal braces at the corners of frame structure to stiffen and strengthen the wall.
Cornerite - Metal-mesh lath cut into strips and bent to a right angle. Used in interior corners of walls and ceilings on lath to prevent cracks in plastering.
Cornice - A horizontal projecting course on the exterior of a building, usually at the base of the parapet. In residential construction, the 0verhang of a pitched roof at the cave line, usually consisting of a facie board, a soffit for a closed cornice, and appropriate moldings.
Cornice Return - That portion of the cornice that returns on the gable end of a house.
Corrosion - The deterioration of metal by chemical or electrochemical reaction resulting from exposure to weathering, moisture, chemicals or other agents or media.
Corrugated - Folded or shaped into parallel ridges or furrows so as to form a symmetrically wavy surface.
Cost Breakdown - A breakdowns of all the anticipated costs on a construction or renovation project.
Counter Flashing - The formed metal secured to a wall, curb, or roof top unit to cover and protect the upper edge of a base flashing and its associated fasteners. This type of flashing is usually used in residential construction on chimneys at the roofline to cover shingle flashing and to prevent moisture entry.
Coupling - In plumbing, a short collar with only inside threads at each end, for receiving the ends of two pipes which are to be fitted and joined together. A right/left coupling is one used to join 2 gas pipes in limited space.
Cove Molding - A molding with a concave face used as trim or to finish interior corners.
Covenants - Rules usually developed by a builder or developer regarding the physical appearance of buildings in a particular geographic area. Typical covenants address building height, appropriate fencing and landscaping, and the type of exterior material (stucco, brick, stone, siding, etc) that may be used.
Crawl Space - A shallow open area between the floor of a building and the ground, normally enclosed by the foundation wall.
Crazing - A series of hairline cracks in the surface of weathered materials, having a web-like appearance. Also, hairline cracks in pre-finished metals caused by bending or forming. (see brake metal)
Cricket - A small drainage-diverting roof structure of single or double slope placed at the junction of larger surfaces that meet at an angle, such as above a chimney.
Cross-Bridging - Diagonal bracing between adjacent floor joists, placed near the center of the joist span to prevent joists from twisting.
Crown Molding - A molding used on cornice or wherever an interior angle is to be covered.
Cupola - A small monitor or dome at the peak of a pitched roof.
Curb - A short wall or masonry built above the level of the roof that provides a means of flashing the deck equipment.
Curing - In concrete application, the process in which mortar and concrete harden. The length of time is dependent upon the type of cement, mix proportion, required strength, size and shape of the concrete section, weather and future exposure conditions. The period may be 3 weeks or longer for lean concrete mixtures used in structures such as dams or it may be only a few days for richer mixes. Favorable curing temperatures range from 50 to 70 degrees F. Design strength is achieved in 28 days.
Curing Agent - One part of a multi-part sealant which, when added to the base, will cause the base to change its physical state by chemical reaction between the two parts.
Curtain Wall - A thin wall, supported by the structural steel or concrete frame of the building independent of the wall below. Also a metal (most often aluminum) framing system on the face of a building containing vision glass panels and spandrel panels made of glass, aluminum, or other material.
Cutback - In roofing, basic asphalt or tar which has been "cut back" with solvents and oils so that the material become fluid.
Cut-in Brace - Nominal 2-inch-thick members, usually 2 by 4?s, cut in between each stud diagonally.
Cut Off - A piece of roofing membrane consisting of one or more narrow plies of felt usually moped in hot to seal the edge of insulation at the end of a day's work.
Closet Auger-A flexible rod with a curved end used to access the toilet's built-in trap and remove clogs.
Closet Bend-A curved fitting that connects the closet flange to the toilet drain.
Closet Flange-An anchoring ring secured to the floor. The base of the toilet is secured to this ring with bolts.
Coupling-A fitting that joins two pieces of pipe.
CPVC (Chlorinated Polyvinyl Chloride)
Rigid plastic pipe used in water supply systems, where code permits.
Cantilever - Any part of a structure that projects beyond its main support and is balanced on it.
Cap flashing - The portion of the flashing attached to a vertical surface to prevent water from migrating behind the base flashing.
Casement Window - A window with hinges on one of the vertical sides and swings open like a normal door.
Cast-Iron Pipe (Plumbing) - Drain and vent lines. Most older Drain-Waste-Venting systems are made of cast-iron pipes-now increasingly supplanted by ABS and PVC. Pipes were originally joined with molten lead, but most plumbers now join them with no-hub couplers.
Cat's Paw - A variation of a pry bar used to pry up deep set (counter sunk) nails.
Catch Basin - A drain for a low or wet spot, with pipe exiting the side and a pit at the bottom to collect sediment.
Cells - (Masonry)The hollow spaces in concrete blocks.
Chalk line - A line made on the roof by snapping a taut string or cord dusted with chalk. Used for alignment purposes.
Circuit - A network of wiring that typically commence at a panel box, feeds electricity to outlets and ultimately returns to the panel box.
Class "A" fire resistance - The highest fire-resistance rating for roofing per ASTM E-108. Indicates that roofing is able to withstand severe exposure to fire originating from sources outside the building.
Class "B" fire resistance - Fire-resistance rating that indicates roofing material is able to withstand moderate exposure to fire originating from sources outside the building.
Class "C" fire resistance - Fire-resistance rating that indicates roofing material is able to withstand light exposure to fire originating from sources outside the building.
Cleanout (Plumbing) - A drain fitting, usually a wye or a tee, with a removable plug to permit inspection and access for an auger or snake.
Cleat - A small piece of lumber attached to another piece of lumber to strengthen or support it.
Closed cut valley - A method of valley treatment in which shingles from one side of the valley extend across the valley, while shingles from the other side are trimmed 2 inches from the valley centerline. The valley flashing is not exposed.
Closet bend - A curved drain pipe that is located beneath the base of the toilet and attached to a closet flange. A slotted closet flange, or floor flange, holds the bend to the subfloor.
Closet Bolts - Bolts whose head is fitted to a closet flange and that protrudes up through a toilet base. A nut is tightened around it on the toilet base. Two (or four) bolts serve one toilet.
Closet flange - A floor flange that's held to the floor with screws or anchors where a toilet mounts directly above it attached with closet bolts and the closet bend attaches below it.
Coal tar - A viscous liquid mixture of hydrocarbon compounds, derived, along with coke, from the destructive distillation of coal.
Code - Rules set forth by various government and private sector bodies to determine minimum trade practices.
Cold Process Adhesive - Mastic prepared with SBS modifiers to adhere laps, flashing and joints of built-up or low-slope roofing without hot-mopping or torching equipment.
Cold-Method and Lap Cement - Special multipurpose adhesive for low-sloped, cold-applied roof construction. Bonds 19" selvedge, mineral surface and cap sheets to the underlayment. Doubles as an adhesive on 2" selvedge lap of mineral-, granule- or smooth-surfaced roofing. Available in both summer and winter grades.
Collar tie - A horizontal board attached perpendicular to rafters.
Common Rafter - Rafter that extends from the top plate to the ridge. Generally set 12, 16, or 24 inches apart.
Compression Fitting - Used to join or connect pipes and conduit by causing a ring to compress against the connecting tube when tightening with a wrench.
Concealed nail method - Application of roll roofing in which all nails are driven into the underlying course of roofing and covered by a cemented, overlapping course. Nails are not exposed to the weather.
Concrete Grout - A mixture of 3/8-inch pea gravel, sand, cement and water that you pour into the cells of concrete-block walls to reinforce them.
Construction Adhesive - Thick-bodied adhesive, suited to a wide range of repair and construction tasks. Packaged in convenient cartridges for caulking guns.
Continuity Tester - An electrical tool used to identify and diagnose a circuit as either open or closed.
Coping joint - The intersection of a roof slope and an exterior vertical wall.
Course - A row of shingles or roll roofing running the length of the roof.
Convection - Air naturally circulated by differences in temperature. Colder, denser air falls and displaces the lighter, warm air.
Coverage - Amount of weather protection provided by the roofing material. Depends on number of layers of material between the exposed surface of the roofing and the deck; i.e. single coverage, double coverage, etc.
Cripple Stud - Short stud used as support in wall openings that replaces a normal 93 inch or 96 inch stud.
Cripple Walls - In a wood-frame house, the section of wall under the house between the concrete foundation and the floor joists. Also called crawl space walls.
Curb (roofing) -The short elevation of an exterior wall above the deck of a commercial flat roof.
Curb roof - A roof with an upper and lower set of rafters on each side, the under set being less inclined to the horizon than the upper; a mansard roof.
Concrete Block - A hollow concrete 'brick' often 8" x 8" x 16" in size. Often used in low rise commercial and some residential construction. The original design and use is attributed to the architect Frank Lloyd Wright.
Concrete Board or Wonderboard (TM) - A panel made out of concrete and fiberglass usually used as a tile backing material.
Contractor - A company licensed to perform certain types of construction activities. In most states, the generals contractor's license and some specialty contractor's licenses don't require of compliance with bonding, workmen's compensation and similar regulations. Some of the specialty contractor licenses involve extensive training, testing and/or insurance requirements. There are various types of contractors:
? General contractor - responsible for the execution, supervision and overall coordination of a project and may also perform some of the individual construction tasks. Most general contractors are not licensed to perform all specialty trades and must hire specialty contractors for such tasks, e.g. electrical, plumbing.
? Remodeling contractor - a general contractor who specializes in remodeling work.
? Specialty contractor - licensed to perform a specialty task e.g. electrical, side sewer, asbestos abatement.
? Sub contractor - a general or specialty contractor who works for another general contractor.
Construction Contract - A legal document which specifies the what-when-where-how-how much and by whom in a construction project. A good construction contract will include:
1. The contractors registration number.
2. A statement of work quality such as 'Standard Practices of the Trades' or 'according to Manufacturers Specifications'.
3. A set of Blue Prints or Plans
4. A set of Specifications
5. Any Allowances.
6. A construction timetable including starting and completion dates.
7. A Fixed Price for the work , or a Time and Materials formula.
8. A Payment Schedule.
9. A written Warrantee
10. A clause which outlines how any disputes will be resolved.
Cost Plus Contract - Same as Time and Materials Contract.
Crosscutting - Cutting across the wood grain; to crosscut a board is to cut across its width.
Curing (Paint) - The process of paint bonding to a surface. Curing and drying are not the same.
Curtain Drain - a ditch sometimes filled with gravel and a drain tile which diverts storm and drain water away from a structure.
Cast iron - Heavy metal formed by casting on molds. The metal is covered with a porcelain enamel coating to make fixtures such as the cast iron tubs found here at Shop 4 Classics. for cast iron bathtubs.
Centerset - A style of faucet that is installed on a lavatory with 4" center-to-center faucet holes and that has the spout and handle(s) combined into a single part. for centerset faucets.
Ceramic disk valve - A type of valve that relies on two-part revolving disks in a sealed cylinder. Each disk has a port in it that, when aligned with the other, will allow water to pass through.
Compression fitting - A pipe connection that seals without soldering. As a nut is tighten on one fitting, it compresses a washer or gasket around the second pipe, forming a watertight closure.
Compression valve - A type of valve that works by raising or lowering a stem. Water passes through the valve by turning the faucet handle, which causes the stem to drop or rise.
Console lavatory - A table-like lavatory in which the basin is attached to a wall at the back and by table or piano legs at the front.
Coupling - Straight, sleeve-like fitting with female connections at both ends.
CO- An abbreviation for "Certificate of Occupancy". This certificate is issued by the local municipality and is required before anyone can occupy and live within the home. It is issued only after the local municipality has made all inspections and all monies and fees have been paid.
Caisson- A 10" or 12" diameter hole drilled into the earth and embedded into bedrock 3 - 4 feet. The structural support for a type of foundation wall, porch, patio, monopost, or other structure. Two or more "sticks" of reinforcing bars (rebar) are inserted into and run the full length of the hole and concrete is poured into the caisson hole.
Cantilever- An overhang. Where one floor extends beyond and over a foundation wall. For example at a fireplace location or bay window cantilever. Normally, not extending over 2 feet.
Cantilevered void- Foundation void material used in unusually expansive soils conditions. This void is "trapezoid" shaped and has vertical sides of 6" and 4" respectively.
Cap- The upper member of a column, pilaster, door cornice, molding, or fireplace.
Cap flashing- The portion of the flashing attached to a vertical surface to prevent water from migrating behind the base flashing.
Capital and interest- A repayment loan and the most conventional form of home loan. The borrower pays an amount each month to cover the amount borrowed (or capital or principal) plus the interest charged on capital.
Capped rate- The mortgage interest rate will not exceed a specified value during a certain period of time, but it will fluctuate up and down below that level.
Casement Window- A window with hinges on one of the vertical sides and swings open like a normal door.
Caulking- (1) A flexible material used to seal a gap between two surfaces e.g. between pieces of siding or the corners in tub walls. (2) To fill a joint with mastic or asphalt plastic cement to prevent leaks.
CCA (Chromated Copper Arsenate)- A pesticide that is forced into wood under high pressure to protect it from termites, other wood boring insects, and decay caused by fungus.
Celotex ?- Black fibrous board that is used as exterior sheething.
Ceiling joist- One of a series of parallel framing members used to support ceiling loads and supported in turn by larger beams, girders or bearing walls. Also called roof joists.
Cement- The gray powder that is the "glue" in concrete. Portland cement. Also, any adhesive.
Ceramic tile- A man-made or machine-made clay tile used to finish a floor or wall. Generally used in bathtub and shower enclosures and on counter tops.
CFM (cubic feet per minute)- A rating that expresses the amount of air a blower or fan can move. The volume of air (measured in cubic feet) that can pass through an opening in one minute.
Change order- A written document which modifies the plans and specifications and/or the price of the construction Contract.
Chase- A framed enclosed space around a flue pipe or a channel in a wall, or through a ceiling for something to lie in or pass through.
Chink- To install fiberglass insulation around all exterior door and window frames, wall corners, and small gaps in the exterior wall.
Chip Board- A manufactured wood panel made out of 1"- 2" wood chips and glue. Often used as a substitute for plywood in the exterior wall and roof sheathing. Also called OSB (Oriented Strand Board) or wafer board.
Circuit- The path of electrical flow from a power source through an outlet and back to ground.
Circuit Breaker- A device which looks like a switch and is usually located inside the electrical breaker panel or circuit breaker box. It is designed to (1) shut of the power to portions or all of the house and (2) to limit the amount of power flowing through a circuit (measured in amperes). 110 volt household circuits require a fuse or circuit breaker with a rating of 15 or a maximum of 20 amps. 220 volt circuits may be designed for higher amperage loads e.g. a hot water heater may be designed for a 30 amp load and would therefore need a 30 amp fuse or breaker.
Clip ties- Sharp, cut metal wires that protrude out of a concrete foundation wall (that at one time held the foundation form panels in place).
Cold air return- The ductwork (and related grills) that carries room air back to the furnace for re-heating.
Combustion air- The duct work installed to bring fresh, outside air to the furnace and/or hot water heater. Normally 2 separate supplies of air are brought in: One high and One low.
Combustion chamber- The part of a boiler, furnace or woodstove where the burn occurs; normally lined with firebrick or molded or sprayed insulation.
Compression web- A member of a truss system which connects the bottom and top chords and which provides downward support.
Compressor- A mechanical device that pressurizes a gas in order to turn it into a liquid, thereby allowing heat to be removed or added. A compressor is the main component of conventional heat pumps and air conditioners. In an air conditioning system, the compressor normally sits outside and has a large fan (to remove heat).
Concrete- The mixture of Portland cement, sand, gravel, and water. Used to make garage and basement floors, sidewalks, patios, foundation walls, etc. It is commonly reinforced with steel rods (rebar) or wire screening (mesh).
Concrete block - A hollow concrete 'brick' often 8" x 8" x 16" in size.
Concrete board - A panel made out of concrete and fiberglass usually used as a tile backing material.
Condensate line- The copper pipe that runs from the outside air conditioning condenser to the inside furnace ( where the a/c coil is located).
Condensing unit - The outdoor component of a cooling system. It includes a compressor and condensing coil designed to give off heat.
Conditions, Convenants, and Restrictions (CC and Rs) - The standards that define how a property may be used and the protections the developer makes for the benefit of all owners in a subdivision.
Conductivity- The rate at which heat is transmitted through a material.
Construction drywall- A type of construction in which the interior wall finish is applied in a dry condition, generally in the form of sheet materials or wood paneling as contrasted to plaster.
Construction, frame- A type of construction in which the structural components are wood or depend upon a wood frame for support.
Continuity tester- A device that tells whether a circuit is capable of carrying electricity.
Control joint- Tooled, straight grooves made on concrete floors to "control" where the concrete should crack.
Convertibility- The ability to change a loan from an adjustable rate schedule to a fixed rate schedule.
Cooling load- The amount of cooling required to keep a building at a specified temperature during the summer, usually 78? F, regardless of outside temperature.
Coped- Removing the top and bottom flange of the end(s) of a metal I-beam. This is done to permit it to fit within, and bolted to, the web of another I-beam in a "T" arrangement.
Coped joint- Cutting and fitting woodwork to an irregular surface.
Corbel- The triangular, decorative and supporting member that holds a mantel or horizontal shelf.
Counterfort- A foundation wall section that strengthens (and generally perpendicular to) a long section of foundation wall.
Course- A row of shingles or roll roofing running the length of the roof. Parallel layers of building materials such as bricks, or siding laid up horizontally.
Credit rating- A report ordered by a lender from a credit agency to determine a borrower's credit habits.
Cripple- Short vertical "2 by 4's or 6's" frame lumber installed above a window or door.
Cross Tee- Short metal "T" beam used in suspended ceiling systems to bridge the spaces between the main beams.
Culvert- Round, corrugated drain pipe (normally 15" or 18" in diameter) that is installed beneath a driveway and parallel to and near the street.
Cupping- A type of warping that causes boards to curl up at their edges.
Mike
Mike
Picking on you. ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
"Continuity tester- A device that tells whether a circuit is capable of carrying electricity."
I can use my "wiggy" on a metal waterline. That does not mean it can carry (allowed to ) current.
It shows that all points are "electrically" connected.
Mike P.
Originally Posted By: mjones1
-A simple, battery-powered tool that indicates whether an electrical circuit is complete or incomplete by lighting or buzzing when you touch its two probes to the wires.
Is this better?
My "WIGGY" tm. Measures voltage. ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Mike
"Is this better?’
A little.
Mike may I bust your chops again???? ![icon_lol.gif](upload://zEgbBCXRskkCTwEux7Bi20ZySza.gif)
"My "WIGGY" tm. Measures voltage"
If it measures voltage I will but it. It indicates 120 or 240. It does not measure.
Please excuse me. I had a "bad" (not for me) day. I had to inspect two flood damage homes (really poor folk) and a renter buying a home from a slumlord. I could not help these people so I want to vent on you guys.
Sorry.
Mike P.
Mike,
That’s ok, We all have days like that. And not to worry my skin is thick as leather.
Last week I had to tell my best friend that the house he wanted so bad was going to cost a small fortune to fix or it will fall down soon. He was very disappointed.(and relieved that I inspected it for him)
Most of this Glossary was cut and pasted from some web sites and I did not go over them as closely as I should have, I will review the rest closer before posting again.
Oh and this is what I woke up to this morning.
http://www.nachi.org/bbsystem/usrimages/0Untitled-22.jpg
Mike
Folks:
This project got too big for me. NACHI staff member Beccah Levine agreed to revamp the Glossary into a database driven one with search tools. She starts working on it tomorrow.
Nick
PS This will not affect the Glossary at the bottom of our SOP which is restricted to terms only found within the SOP.
Originally Posted By: jrooff
Maybe a Glossary on all the Abbreviations that the older non-computer wizes out here.
Glossary done.
Thank you all.
I moved topic to this thread: http://www.nachi.org/bbsystem/viewtopic.php?p=23596#23596
Nick
