Hello! I understand that a 240v circuit can work without a neutral because each conductor “takes turns” acting as the neutral? Is that correct? And if so, how is it still providing 240v total if both wires are taking turns being the neutral? Wouldn’t that just be 120v at any given moment? Please help me learn! Thanks!
I didn’t know either so I looked it up, ChatGPT explained it really well, so here’s what it says.
Great question Robert.
Why a 240V Circuit Doesn’t Need a Neutral
A 240V circuit in the U.S. consists of two “hot” wires, each carrying 120V, but they are 180 degrees out of phase with each other. This means:
- When one wire is at +120V, the other is at -120V at the exact same moment.
- The voltage difference between them is 240V (because +120V - (-120V) = 240V).
Why There’s No Neutral in a Pure 240V Circuit
- In a 120V circuit, the current flows between the hot wire and neutral, with the neutral providing a return path.
- In a 240V circuit, the two hot wires are already providing a complete path for current to flow back and forth—so no neutral is needed.
- Each hot wire alternates between pushing and pulling current, but they are opposites at all times, keeping the full 240V difference.
Wouldn’t It Just Be 120V at a Given Moment?
No, because voltage is always measured as a difference. Think of it like a seesaw:
- If one side is up at +120V and the other is down at -120V, the total difference is 240V between them.
- This means a 240V appliance (like a water heater or an electric stove) is always receiving the full 240V potential difference, even though each wire is alternating between +120V and -120V.
That’s very helpful!
I guess I’m having trouble understanding how volts work. I understand they are the “pressure” of the current. But I don’t understand how measuring the difference is a good measurement for “pressure.” For water we use psi. That makes sense to me. “Difference” doesn’t.
Bobby Mascio
InterNACHI® Certified Professional Inspector (CPI)®
Illuminate Home Inspections
I guess you could look at it as one end of a hose pushing 120psi and the other end of the hose sucking 120psi. It’s a terrible analogy but the ‘difference’ between the +120 and the -120 is 240. so 240psi of “working load” is being applied.
Does that help?
AC electricity is push pull.
It flows one way, then it flows the other way. In the USA this happens 60 times a second. Volts is the pressure, Amps is the volume.
Butter churn? Down, then back up?
Shake Weight? The old sex manual; Insert, remove, repeat if necessary?
DC current is more like the water hose except the electrons can’t just flow off into space if you hold up the end of a wire.
So much for AI, the two halves of a 240 volt signal are NOT out of phase with each other. This is single phase. Only because they are single phase can the two 120v sine waves create 240v.
it also has to do with how electricity “flows” with respect to water. water atoms move when it flows, but when electricity flows, it just moves the free electrons in the outer valence shell of the atom used as a conductor. copper is a good conductor because it has free elctrons to exchange. silver and gold are better because they have more free elctrons while wood is a poor conductor because it has none in the elements that make it up.
so while water actually has the whole atom moving, electricity only moves electrons and not the whole atom like water does. that is the main difference and the reason wires don’t move like water moving through a pipe. i had to learn the fundamentals of electricity to work on electronics. i do hope they haven’t changed it too much in the last 30 years…
I think that you’re over complicating the answer. Forget AC or DC for a moment and think that if you connect a meter across you car battery it reads 12 volts. That 12 volts is the potential difference between the two terminals. Now connect a meter across the two legs of your electric panel and it reads 240 volts that’s the potental difference between the two terminals.
One is a 12 volt system the other is a 240 volt system in either case connecting a load netween the two terminals will allow current to flow through the load. With the 240 volt example there is no neutral and in a 2 wire AC circuit there is no “return”.
First forget the water analogy. Water flow is the movement of matter (liquid) from one location to another through a pipe stream aquaduct, whatever.
Electricity is simply the difference in potential (one negative the other positive) between two points on a wire (nothing moves).
In DC this potential at the two points always stays the same polarity. Think of a battery, a simple chemical reaction creates the voltage potential. Nothing moves; polarity always remains the same.
In AC the potential at the two points alternates between positive and negative. In the USA this occurs at 60 times a second. Pure AC is generated by a coil of wire rotating inside a magnetic field. Think of a circle. This is why half of a circle (180°) is drawn above (+) a line in a graphical representation (sinewave). and half (180°) is below (-) the line.
Thank you for the info
That’s great analogy! My mind still would think that the most you would get from that is 120v since I picture the volts needing to go in the direction of the appliance in order to get the volts. If that makes sense. If 120 is going “away” from the appliance at any given time I think it’s not getting that voltage. Does that make sense?
This is very helpful. That water analogy keeps messing me up. My mind keeps thinking of volts in terms of “flowing” somewhere. That’s what’s hanging me up I think.
Not really. Say you have a two-wire, 240 volt circuit. There is no 120 volts because it’s a two wire circuit. Connect a 240 volt load between those two wires and 240 volts will be flowing from the source through the load and back to the source.
Water “flows,” electricity does not flow. We are past the water analogy. It is a poor representation of electricity and not helpful or accurate.
Voltage is the difference in potential, electricity does flow it’s called current. In a complete circuit there is current flow and the pressure of that flow is the voltage.
This is a terrific example! Very helpful! Is there another way to say “potential” that my pea brain can understand?
Bobby Mascio
We are not on current yet. We haven’t moved past voltage. The word flow implies movement as in the water analogy and is not helpful. Current does not “flow” any more than voltage does.
That description is simply a “visualization” of electricity for simplification.
I never mentioned water so those words are not part of my analogy. Current or current FLOW is the measurement of the number of electrons passing a single point. So yes current flow is correct.
Let’s leave current out of this.
I would just add, since I think nobody has raised it yet (scanning through the comments): Most 240V appliances NEED a neutral. The reason is simple. Although the heating or burner elements, large motors, and so forth, run on 240V and do not need a neutral, there is typically internal control board circuitry, lights, small motors, and so forth, the run on standard 120V.
True many do. Let’s assume that this is a water heater. ![]()
