Heat Pump or AC?
Goodman
Model # CPLJ36-1A
Serial # 0405031025
That Model should be a heat Pump
Thanks…
What are the rules of thumb to figure out whether it’s heat pump or furnace? Assume could not the model number on Google.
Th Dad
some makes have a H in the model Number, Best thing is to look for the switching Valve when checking out the unit.
Here is a drawing that may help
I generally look for a reversing valve and an accumulator.
Yes Blaine, but you, unlike many of the new Florida “professional” home inspectors, know what a reversing valve and an accumulator looks like and its purpose. Most wouldn’t know an accumulator from a flux gate capacitor.
I just use my tricorder
The data plate says “central cooling air conditioner” in the bottom left. It’s not a heat pump. If it was, it would say “heat pump”.
In no particular order:
Joe the air handler does not have to be electric I have a gas fired furnace with a heat pump condensing unit on the exterior of my home refered to as a duel fuel
Yep. Dual fuel systems. Thanks for the correction.
Your welcome
