Is that when it switches over to an aux heat source?
Heat pump operation depends on the type of refrigerant, the newer R410 is much better since it is used in units that have other advanced designs.
At 15 deg F, some heat can be absorbed from the exterior but most likely it was running in regular and aux heat strip mode at the same time if you had good warm air. If you had the t-stat up over 2 degrees it would have been running the electric strips also unless programmed out via a special t-stat that also uses an exterior temp sensor. Some units can even sense that the house is not gaining any heat and will add in the aux strips even at a one degree t-stat command.
The thermostat at this home indicated it was running in normal heat mode. The heat pump was running when I arrived and I tried turning up 10 degrees to see if the aux heat would automatically turn on. It did not.
