From the top, I’m a curious / data-driven home-owner. This message is a corroboration to Bruce King’s 11/11/06 post about sizable temperature differentials for modern HP’s.
My experience today: 60F ambient temp, 1-year old Coleman 18 SEER 2-stage Copeland-driven HP running on Hi stage; The return temp at furnace air filter = 64F, output temp taken in living space at the 1st wall-register beyond add-on HP atop oil furnace = 102F for a 38F differential. One mod I’ve done - I added a 2nd layer of insulation on the vapor line from the HP to the indoor coil, about an 18’ run. I suppose this helps…
It’s easy for me to monitor HP 1st/2nd stage performance + FF operation. I’ve installed at the T-stat a pair of LED status lights that confirms the FF operation and HP-2nd stage operation.
