Home / Garage Separation
Originally Posted By: jhagarty
Joseph Hagarty
HouseMaster / Main Line, PA
joseph.hagarty@housemaster.com
www.householdinspector.com
Phone: 610-399-9864
Fax : 610-399-9865
HouseMaster. Home inspections. Done right.
Originally Posted By: tallen
I do not know of a code reference. However, every one I have ever seen swings into the house.
I have put the past behind me,
where , however, it now sits, making rude remarks.
www.whiteglovehomeinspections.net
30 Oct 2003-- 29 Nov2005
A Fire Door is Required. Does it matter which way the door is hinged??
Joseph Hagarty
Phone: 610-399-9864
Fax : 610-399-9865
Originally Posted By: wpedley
Most of these doors are installed to swing in.
I am not aware of any code stating otherwise.
As a vol. firefighter it is always easier to close a door in the
event of fire by pushing it verses trying to pull it shut. ![icon_cool.gif](upload://oPnLkqdJc33Dyf2uA3TQwRkfhwd.gif) This
is why all bedroom and bath doors swing in.
BPedley
Inspecting for the unexpected
Originally Posted By: Vince Santos
If a garage door swings out, it would swing over the stairs right?
Desire is half of life, indifference is half of death.
–Kahlil Gibran
Originally Posted By: Todd Patrick
Vince, Joe said there were no stairs.
Joe I have never seen a code anywhere stating swing direction requirements for a fire door. I would think a fire door is a fire door and it shouldn’t matter one way or another.
If it were me, and its not. icon_razz.gif I would just write it up as not a typical installation of a fire door. Doors are normally installed to swing inward toward the living space.
Originally Posted By: tlempe
The one in my own home swings outward
Originally Posted By: phinman
Joe H,
I spoke with a fire official about the door situation. He said because it is not a "required means of egress" by the code BOCA or otherwise that the swing of the door is not an issue swinging in or out.
As you know you should not swing a door out over a stair.
Phillip R. Hinman
VP Tri-County Construction Code Association
NJ NACHI
I have been going nuts looking for a requirement.
Originally Posted By: jpeck
And that the garage is not conditioned space, so the door, which ever way it swings, needs to be solid core and weatherstripped, just like any door to the exterior (because that is what it is).
Jerry Peck
South Florida
Originally Posted By: rcloyd
Joe:
If there are stairs from the garage floor up to the 1st floor of the house (very common) the IRC requires a landing at the top and bottom of that stair except the top landing may be omitted if the door does not swing over the stair.
There are several advantages to having the door swing inward to the house:
1) You don't have to build a 3'x3' landing within your garage space.
2) Security. Your hinges are not exposed to the garage area leaving them
vulnerable to removal and providing easy access to the interior once
the door is removed.
3) It is much easier to unlock the garage door and push it out of the way
when your arms are full of packages or groceries.
4) Oh yeah, if the door swings out into the garage into a vehicular path
death or serious injury can occur.
Regards,
Russell G. Cloyd
Intra-Spec Home Inspections
& Code Consulting, LLC
859-586-4591
www.intra-spechomeinspections.com
Originally Posted By: dbroad
Swing it towards the house, unless there are steps going down to the garage, then it swings out.
Originally Posted By: lkage
Huh?...well, if there is a landing but not over the steps.
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Doors (including garage doors) can not swing out over steps. Even though there may not be stairs, I usually see at least one step down from the house to the garage … in which case model codes would not permit the door to swing out into the garage without a platform/landing. That is for personal safety, and not fire safety.
Another consideration is that if the door swings out into the garage (with a platform at the door), the hinges will be on the exterior, which could allow easy entry by removing the hinge pins (those doors very rarely have NRP or stud hinges). People concerned about home security are usually pretty good about locking standard doors, but will often leave overhead garage doors open or unlocked.
Just my opinion and 2-nickels ... ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
