I have a question about hot water tanks, the cold supply line feels warm up to a foot leading into the hot water tank, with no expansion tank installed. I did hear that all Hot water tanks should be installed with a expansion tank, but without the expansion tank would anyone consider a warm supply line an issue. Good point Bob something to put in my notes for future inspections.
My gas water heater only reads about 2 degree’s different on the inlet and outlet. The outlet (hot water) is the higher reading.
I suspect that if I run the hot water somewhere in the house the difference between the two pipes at the water heater would be much greater.
My conclusion is that a water heater that has stabilized (no flow) will show fairly equal temperatures even though the hot water reflects temperatures in the top of the tank and the supply line reflects temperatures at the bottom of the tank.
I was not sure with the hot water pushing warm water back up into the supply line was the next thing going to happen is setting off the TPRvalve, if there was no expansion tank installed.
Good reminder Thanks Marcel.
I have town water at 115 Lbs. and reg to drop House pressure to 50 Lbs. and .reg to drop pressure to lawn sprinkler to 80 Lbs. and two expansion tanks .
As Chuck pointed out an expansion tank is required on a closed system.
Marcel properly defined that as one with a pressure regulator between the house and the city supply. Water cannot expand back into the city supply line.
Wells are closed loop systems where water is pumped into the pressure tank and held at a working pressure till used. Water cannot expand back into the well.:mrgreen:
