How do I enter in report Code violation since we are not code inspectors
As home inspectors, we’re not code enforcement officials. If you find a condition that doesn’t meet current code, how do you explain it to the client without calling it a code violation? What wording do you use in your report?
Just describe the defect and use the applicable code as a reference, if you so choose.
It would help if you could provide a specific example of what the issue is
I like to use the term “current standards,” or variations of that depending on the circumstance.
Current standards is so vague that it can mean just about anything, which shouldn’t get you into any trouble. :grinning_face:
Simply describe the defect in your report. If it’s a potential safety issue, state that as well.
I’ve found that best practice is to keep it simple.
Yep, the last thing you want to do is mention actual codes, as you would be presenting yourself as a code official, which requires a specific license in most jurisdictions. “Current Standards” just means it is not done how it would likely be done today.
If you mention the actual speed limit does that mean you’re presenting yourself as a law officer? :thinking:
Yes, if you have pulled someone over. In the same sense, if you are doing an inspection, and mention code, you have set the precedent that you have inspected the house to code, which you can’t do if you are not licensed, in my opinion.
Are you claiming to be an expert on just how fast they were going?
Are you allowed to reference a dictionary for the correct spelling of a word?
:thinking:
Not claiming anything, just noting what the speed limit is.
I don’t think spelling or using a dictionary requires a license. But anyways, if you are going to mention codes, be sure you inspect the entire house to the applicable code.
“Modern Standards”… “Accepted Industry Standards”… “For Improved Safety…”, etc…
What about manufacturer installation instructions? If you quote that, are you presenting yourself as the manufacturer?
Are you just saying that you would bring up a speed limit in casual conversation or is there a reason to bring it up?
Or are you using it like the people that complain on a local FB page that the cars that go past their house everyday are going at least 80 mph in a 25 mph zone?
If you quote the manufacturer instructions for the water heater are you required to provide manufacturer references for the HVAC, electrical equipment, appliances etc?
:thinking:
It could happen.
Spin how you want.
What about reading? Does that require a license?
Does the manufacturer require a license to interpret and enforce their instructions? Does your local jurisdiction require a license to interpret and enforce manufacturer installation instructions?
