According to the Res. SOP:
2.10. Doors, Windows & Interior
I. The inspector shall:
D. inspect garage doors and garage door openers by operating
first by remote (if available), and then by the installed automatic
door control.
What is an “automatic” door control? Is that referring to the push button switch mounted usually on the wall? What’s automatic about a button?
If you push the button, the door automatically goes down or up. You don’t have to walk over to the door and physically push it up or down since it’s automatic once that button is pushed.
door control.
The SOP requires you to operate the garage (ie. open and close) FIRST with the remote. You have to open the open the door with the remote FIRST.
Why?
And what happens legally if you do not follow the SOP? Are you exposing yourself to legal problems?
maybe a little with this particular examination of this SOP clause…
but the bigger point - the SOP is designed to protect us - it should be under constant scrutiny and evaluation. (without an emotional outbreak from those not interested in that task)
I agree, I think it needs to be removed from our SOP. Can somebody from NACHI please remove the phrasing so we can perform the inspection either way.
Thanks, Ben, for pointing this out.
Where I come from…** GROSS NEGLIGENCE and WILLFUL MISCONDUCT!**
hee hee
My point is not actually these small details of the SOP that seem “in need of tweeking” IMHO. Such as…
E. and report as in need of repair any installed electronic sensors
that are not operable or not installed at proper heights above
the garage door;
Sensors should not be installed ABOVE the garage door. Correction to the SOP is obviously needed here.
**The main point for me is: **
I’m doing what I believe we all should be doing. Evaluating and scrutinizing the SOP that is designed to assist us in our profession. I bet most of us have not even read the SOP in detail (and with a little devil’s advocate inside us).
I encourage all inspectors to:
Once a year - take a look at the SOP, and ask “Is this the best? Can this be improved? Is there something missing? Should it be written differently?”
How many inspectors actually use the remote. I have never used one. If you want to clean up the SOP then remove that line. FYI - it might be a good idea to have it removed. If you ever go to court and say you follow the SOP, the opposing lawyer can make you look silly over something stupid like this.
I’m almost at a point where I don’t want to follow the NACHI SOP anymore. Seems to me after all this time the SOP would be nailed down by now. Just my observation.
I wrote the first draft many years ago in Nick’s basement in PA. It was obviously not as developed as its present version. I remember that I called it the “Standard of Practice” and Chris Morrell changed it to “Standards” with an “s.”
