For this assignment, I took a look at my own home and evaluated the various components that relate to moisture intrusion. The signs of moisture intrusion are many and quite obvious, but I also have the luxury of knowing firsthand where the biggest issues are and the reasons they exist, which I wouldn’t ordinarily be privy to in a typical home inspection.
The following is a brief summary description of my home in general as well as the systems and components of my house that are relevant to moisture intrusion:
The home was constructed in 1926, and added onto at least twice. Some of the moisture issues present are at least partially due to or aggravated by the additions not being tied into an overall moisture/drainage strategy, making prior issues worse than they may have originally been. Some of the other issues can be attributed to extremely old features that are commonplace in other houses I’ve inspected of roughly the same era of construction. The foundation is the original brick and mortar used at the time the house was built in the 1920’s, sitting atop a thick concrete wall or footing on the front and sides of the home that surrounds and forms a wall around the dug out section of unfinished basement. About 2/3 of the house sits above an unfinished basement section, while the front 1/3 sits above a crawlspace section. The HVAC unit, ductwork, and water heater are located in the basement.
Here are some of the exterior areas I inspected, with notes pertaining to moisture intrusion:
*GRADING: the first thing you notice when arriving at my home is that the structure is built below a road that has been widened over the years, which continues to be the biggest contributing factor to my ongoing moisture issues. There is nothing that can really be done about this; it is what it is. The front yard slopes directly down to the front of the house before flattening out somewhat the last several feet before reaching the foundation. Despite the modest leveling of the yard near the house, this still directs massive amounts of surface water from the road directly to the foundation where it has nowhere to go. I’m in the process of cutting a diagonal trench or swale across the yard to intersect the flow of water and carry it safely to the end of the house where it can drain downhill a safe distance from the foundation.
*DRIVEWAY DRAINAGE/GRADING: this is another major contributing factor to basement water intrusion. Originally (up until just prior to us buying the home in 2009), the driveway was gravel and grass, and gently sloped away from the home based on old pictures we were able to obtain. This would allow much of the water to funnel away from the house to the lower area at the bottom of the driveway. Unfortunately, the driveway was paved with asphalt which is actually graded in the opposite direction (towards the house) and built up to be several inches above the low lying area right up next to the foundation. This encourages water to be funneled from the hillside across/down the driveway towards the house, where it is trapped in the lower lying area next to the foundation with nowhere to go. I was able to partially alleviate some of the problem by constructing a berm in the lowest lying area, and a dry creekbed which helps redirect some of the surface water diagonally away from the house to a lower point further down the driveway during periods of heavy rainfall.
*ROOF DRAINAGE/GUTTERS & DOWNSPOUTS: another major factor I have only recently figured out, thanks to this training! No evidence of current or prior leakage detected in the roof structure itself. The problem lies in the drainage of roof runoff into improperly installed gutters and poorly located downspouts. The gutter along the front of the home, which drains from the largest area of the roof was installed with an improper slope, so that the middle of the span of gutter is actually raised higher than on either side. This means water on the right end of the gutter actually has nowhere to go since it cant drain uphill, causing frequent overflows during rain events as evident by water damaged soffit and staining of the gutter. In addition, the contractor who installed the gutters and downspouts chose to locate the sole downspout at the end that terminates directly into the low lying problem area mentioned above, directing a massive amount of water into the worst possible site where water already pools and collects from a) the downsloping yard, and b) the down-sloping driveway. After many instances of performing my own “rainwater studies” during heavy rains, I’ve been able to pinpoint this as the exact location where water is initially infiltrating the foundation, flowing along the foundation until it hits the thick concrete footing wall separating crawlspace from basement and ultimately flows into the basement section where the chimney penetrates the concrete wall.
Now that I have pinpointed the exact point of origin where water is infiltrating the basement/foundation and identified the flaws in the gutter and downspout/grading contributing to the issue, I feel fairly confident that I can alleviate the bulk of the problem by undertaking the relatively easy, low-cost improvements on the exterior of the home mentioned below as opposed to (ineffectively) trying to deal with the symptoms of the problem via hours of fruitless water sealing efforts in the basement itself. These courses of action include:
a) digging a trench/French drain or swale that runs diagonally across the front yard to intercept the surface water coming from the road and divert it downhill to terminate safely beyond/below the foundation
b) re-installing the front gutter with proper slope and relocating downspout to opposite end.
