How To Perform Deck Inspections Video Course
(Ben J. Gromicko) #1
This online student discussion thread is dedicated exclusively for students who are currently enrolled in the InterNACHI free, online “How to Perform Deck Inspections” video course.
Students may pose questions, post images, and write essays for this course.
Need assistance? Ben Gromicko ben@internachi.org
(Cameron Cashman) #2
I already posted in the original modules.
(Sean Cooper) #3
Here is a deck that displayed what appears to be rotted or decayed wood on the joist. I wrote this as a safety hazard and needed repairs by a certified contractor.
(Gary Ambrosia) #4
This is a picture of a front porch where the outside deck and siding have rotted due to using tongue and groove decking so water collected and rot took over.
Thanks,
Gary Ambrosia
(Gary Ambrosia) #5
Client name: Crissy McFadden
Inspected property address: 1114 Piedmont Ave
Date and time of the inspection: 02/18/15 2:30 PM
Weather conditions: Partly cloudy
Approximate outdoor air temperature: 66
People present at the time of the inspection: Inspector Gary Ambrosia
Estimated year built: 1966
Type of structure inspected: Single story single family dwelling
Company name: Ambrosia Inspection Services
Inspector name: Gary Ambrosia
This home has all new exterior including siding, decks, doors and windows
Company phone: 831-402-2398
Company email: gary@ambrosiainspections.com
Company address: 1114 Piedmont Ave., Pacific Grove, CA 93950**
EXTERIOR
INSPECT:
x I inspected the exterior wall-*‐covering materials, flashing and trim.
      The exterior wall-*‐covering materials, flashing and trim were not inspected, because they were:
       inaccessible
       unsafe
       not present
       not within the scope of the inspection
file:///C:\Users\gary\AppData\Local\Temp\msohtmlclip1\02\clip_image001.gif
x I inspected all exterior doors.
       All exterior doors were not inspected, because they were:
       inaccessible
       unsafe
       not present
x I inspected the adjacent walkways and driveways.
      The adjacent walkways and driveways were not inspected, because they were:
       inaccessible
       unsafe
       not present
x I inspected the stairs, steps, stoops, stairways and ramps.
      The stairs, steps, stoops, stairways and ramps were not inspected, because they were:
       inaccessible
       unsafe
       not present
(Gary Ambrosia) #6
I just read the article on “Earthquake Preparedness”. I live in Monterey/Pacific Grove, California. I have lived through a number of earthquakes both large and small. I have done a good deal of earthquake repair and sizemic retro fit as a contractor for the last 38 years. As an inspector I am very aware of the potential for damage from earthquakes and take an extra look at structures during inspections. Just waiting for the next big one. It will happen.
Thanks for the article. Very good information for prevention of health, safety and structural problems.
Gary Ambrosia
(Jason L. Grosse) #7
I just read the article on inspecting decks, which is a basic overview of the video course. I think that it was very informative and will help me in future inspections. I do wonder how similar inspecting a deck around a house on stilts would be to an average deck.
If anyone one knows of additional reading on stilt houses or if I just have not gotten to it yet, please let me know.
Thanks
(Patsy Wright) #8
Very informative course…I appreciated the shorter videos!
Attached is a picture of a section of deck ledger at the home we rent in GA. The ledger is directly attached to the brick veneer of the home, which can be a safety issue.
(Patsy Wright) #9
I inspected the deck at our rented home and found the following:
The ledger board is attached directly to the brick veneer.
Some of the boards were showing splintering, rotting, and nail head protrusion.
The posts did not appear to be resting on footers, but am unable to make a clear determination of this. One of the posts was clearly not attached, but was sitting directly on top of a brick retainer wall, at the corner of the deck.
The deck would benefit from additional lag bolts.
Recommend a qualified contractor replace the rotting boards, and anchor the corner post.
(Patsy Wright) #10
For the supporting article to the is course, I read “How to Inspect a Deck, Illustrated.” I enjoyed the article and the accompanying pictures, which were the same ones in the video course. However, the article reinforced the necessary aspects of performing an adequate and professional inspection and having the visual assisted in my remembering what I had viewed on the videos.
Thank you for an excellent course! :cool:
(Rod B. Nelson) #11
This deck is on a house in Florida. It is unfinished but the stairs were redirected as a safety issue because they were terminated in such a way that if you tripped coming down them you might go swimming. Accidentally.
(Rod B. Nelson) #12
I read the article on inspecting decks. I was a bit horrified to learn that when you notch a rail post and put 200 lbs of pressure on the post it puts 1700 lbs of pressure on the top bolt! I have been doing that for years… No longer however. Thanks Internachi!
(Herbert Webb, HI8809) #13
I live in SW Florida. There are no decks because of the humidity and rain fall.
(Haji Moore) #14
The railings on my front porch are too wide to grab. Which in turn is a safety issue that I’ll be looking for thought my home now that I have more insight about what to look for.
(Scott MacLean) #15
In my home remodeling business I have designed and built a lot of decks. During construction the pressure treated decking is wet. I always place them together without a gap so as it dries so a normal gap will be created. If you don’t, the gaps become very large. I would verify the date of construction or check the moisture content. What are your thoughts?
(Jon C. Stetson) #16
Thus photo shows a staircase leading to a warehouse deck. The graspable handrail is properly installed, however the infill spacing in the railing is not adequate.
(Jason L. Grosse) #17
This is a small deck over looking a creek. The wood does come in direct contact with the ground in many locations but dos seem treated and not currently showing any signs of rot. The railing is in good condition along with the floor.
(Jonathan LaBron) #18
Hi Everyone,
I would like to know if I should recommend to the customer to use a vapor barrier under this deck to extend the life or use a weather sealer or both.
](http://www.google.com/imgres?imgurl=http://www.raftertales.com/wp-content/uploads/2007/11/building-outdoor-deck.jpg&imgrefurl=http://www.raftertales.com/home-improvement/deck-building/&h=333&w=500&tbnid=V3ES_SehynmpVM:&zoom=1&docid=XYB4ST7xr2W1XM&ei=UZnzVJeFC4mMsQTzqIH4Dw&tbm=isch&ved=0CF0QMyg2MDY) https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcQ9KAj0DmPOGY2QYIsEO7V95B38ieN2rnZ5ELyq2F9OKvOj8VgK
(Howie Boyda) #19
Hi Everyone,
Please view picture attached to this thread.
The guard railing has horizontal boards and too much spacing in between the boards - this is a fall safety hazard for children.
Howie Boyda
Canadian Residential Inspection Services
(Howie Boyda) #20
Hi Everyone,
Results of Deck inspection required by course:
  • Ledger board mounted with normal nails with no weather protection coating.
  • Guard and Hand railing has horizontal boards with two large of spacing in between boards.
    The pillars were placed directly onto grade with no securement for preventing lifting or side ways movement.
    Consult a qualified contractor to repair the above safety issues.
Thanks
Howie
