GUTTERS, SPLASH GUARDS, AND DRAINAGE. GUTTERS COME IN MANY DIFFERENT SIZES, SHAPES AND MATERIALS BUT IN THE END ALL PERFORM THE SAME JOB, TO DIRECT WATER AWAY FROM THE FOUNDATION AND THEN OUT INTO THE YARD OR INTO A DRAIN.
INSPECTING A RECEPTACLE… FAIRLY EASY. STICK IN THE TESTER AND LOOK AT YOUR LIGHTS. REALLY THE TESTER IS DOING THE HARD PART, YOUR JUST MAKING SURE THE CORRECT LIGHTS ILLUMINATE AND THE GANG BOX IS SECURELY FASTENED. IF IT IS A GFCI MAKE SURE IT IS FUNCTIONING PROPERLY.
In 2017, OSHA reported 87 work-related fatalities from falling off/through a roof. When deciding whether or not to walk a roof, one must consider environmental factors as well as the condition/composition of the roof covering.
High wind, rain, or snow may prevent you from walking the roof. A multi-story, steep pitch roof may not be the best to walk. Additionally, roofing materials such as tile and slate should never be walked. If the roof is deemed safe to walk, roof walking boots or soft soled sneakers should be used to maximize traction.
Alternatives to walking the roof include a visual inspection using binoculars or from a ladder along the roof edge. A telescoping pole with a camera or a drone can also be used.
Ladder Safety:
Inspectors use a lot of tools to assist in the inspection process. One tool, possibly the most dangerous, is the ladder. Ladders come in many different types and lengths. It is important to have knowledge on the types of ladders and their intended use. The knowledge should not only be on the types but also on all the parts. Ladder injuries as well as deaths have increased significantly over the last several years. These injuries and deaths can easily be reduced by knowing the ladder types, uses, and how to maintain them.
I chose to write about the solar panel roofing image. I learned two things from this image. First I learned about solar panel shingles in general, I have never seen or heard of this technology for roof covering. Second I learned about installation of the panels. I see they are installed on nailers perpendicular to the rafters.
Pictured is a roof and flashing components in good condition and installed correctly. The roofing cover is asphalt architectural shingles. Two tubular skylights ads installed as well as vent stacks and roof vents. Typically, roof vents are installed in a straight line or parallel to each other but the offset presents no issue other than not being as cosmetically pleasing.
There is a repair on the ridge of the rear gable. Repairs often indicate previous damage that may allow water intrusion. This repair has been applied in a manner that may not be secure and not to industry standards. I recommend a roofing professional for further evaluation and repair.
my essay is on the graphic library of step flashing.
The necessity of step flashing and counter flashing is to divert water away from a standing seam that could possibly hold water and or allow water to seep under roof coverings and underlayment. thus allowing water to intrude roof sheathing and trusses along with attic space and interior of home.
Roof coverings are designed to keep out moisture. It is important to remember that there are different ways moisture presents itself. Snow, Ice,
rain, condensation ect. When inspecting a roof covering take all these things into consideration so as to make a proper assessment of the roof covering.
Choosing a domain name … When choosing a domain name you want to make a decision thats in the best interest of your business. You do not want to create a domain that is going to be hard for someone to remember or hard to access. Something short and catchy is optimal.
Roof covering is a Three Tab Shingle . There is damage to this section of the roof covering , shingles appear to be worn and curling, cause unknown. No vegetation or limbs rubbing against it. Would get a licensed and insured professional for second opinion.
Attached to this file is a photo of a roof. I noticed that the flashing was installed improperly at some point in the past. Before continuing any further i would recommend a professional roofer inspect and correct the issue with the roof.
How to inspect roof systems. First taking adeuate pictures from not only ground level but also roof edge and various places around the surface of the roof. Also checking any penetrations including flue caps, roof vents, chimneys, etc. otherwise looking over any any all items.
So upon inspection the property was having the primary water barrier installed on the roof of the house they were using modified bitumen and the installer were waiting on the county inspector to sign off on the installation of the capping nails. Then the secondary water barrier would be installed and the shingles would go on after. Upon further inspection the installers were using 8d nails into the rafter which were 16"oc and no visible water stain were noted from the previous shingle installation. The inspector after further inspection could not find any other faults with the shingle installation and will return to the inspection upon completion of the project.
This article is about roof sheathing and how to inspect it. Some of the sheathing used to day is osb, plywood, and composite panels which uses combined veneers. Sheathing basically it the foundation for the roof covering. So if visibly available one can read the rated sheathing requirements per the manufacturer for example 24/16 which is the allowable roof span for the sheathing and the second number is the maximum span when the sheathing is used as flooring material. Plywood panels should be laid with grain perpendicular to the rafter boards. Depending where the house is built is also going to be a certain way of fastening the sheathing to the rafters so if the wind speed is greater than 130mph the nails will be attached 6"oc for at least the first 48 inches. So when inspecting a roof these are some of the things one can look for and also when completing a new construction inspection or reroof.
The open valley shows signs of deteriation and several layers of shingles, missing flashing at the bottom of valley where it meets overhang. Nail heads are visible to the east of valley. Missing and damaged shingles. Roof vent not attached or flashed properly. Correction required and reevaluation from a roofing contractor recommended.
Knowing what year the house you are inspecting can be very helpful in finding the use of aluminum wiring. When aluminum wiring is found in a home it seems likely that the electric bill would seem a bit inflated considering how ineffective aluminum is as an overall conductor. The cost of replacing the wire can be somewhat offset in the savings on utility bills not to mention the safty factor
The article I selected is “Inspecting step and kick-out flashing”. I have learned that when inspecting step and kick-out flashing. Some areas in high wind require continuous sidewall flashing because it is more wind resistant.Kick-out flashing should be installed to direct water into gutters. It is important that kick-out flashing is adequately sized for proper water flow.
I looked at the structure of the roof and took note that there were factory built rafters, attached to the wall with hurricane clips and also used “H” clips when installing the sheathing for the roof. I also took note that at the peak there was a ridge cut out for ridge vent.
Upon inspection of this dry fertilizer barn; I have notice the auger system was not installed with proper flashing. A few different types of sealants were applied. During further inspecting I have noticed several soft spots in that area due to water intrusion. Further evaluation by a licensed professional and correction will be needed.
