I see about prohibition of bathrooms but which part explains why in that code book ?
Which code book is that from ?
You have moisture entering the system, as Bob said negative pressure from mechanical exhaust (if there is one) and the Aroma (oder) from bath entering the return/supply.
That is from the 2006 International Residential Code pg 339
I suppose Uncle Aldo might have the skills to create enough methane to blow up the joint after a good burrito dinner.:eek:
Very clear I truly appreciate the wisdom , thanks
Think someone in the shower and the A/C/heater kicks on with a return air in the bathroom where does all the moisture go not out the exhaust fan because it is being over rode by a much larger CFM. Same principle with a kitchen exhaust fan which is larger do the math;-)
As for the bathroom; what do you thing happens when you shut the door?
Plumbing fixtures turn into mini-jacuzzi’s. great way to turn your toilet into a bidet!
George, though it may pass construction standards it is still “wrong” (For other reasons).
