Originally Posted By: ccrooker
What is the biggest problem of ice damming when you come across it
Originally Posted By: cmccann
NACHI MAB!
Originally Posted By: lkage
| cmccann wrote: |
| All the above. |
"I have never met a man so ignorant that I couldn't learn something from him."
Galileo Galilei
Originally Posted By: clawrenson
Ontario Home Inspections Inc.
Originally Posted By: rparker
Originally Posted By: lewens
Just my usual 12.5 cents
NACHI MAB!
Originally Posted By: rcooke
| lwillick wrote: |
| If the attic has at least 14 inches of insulation then free flow turbine spinning vents can be installed on the roof. They aid in keeping heat and humidity out of the attic in the summer months and moisture, etc out in the winter months. It is, however, important to have adequate insulation in the attic and also some soffit/eave venting to allow the correct "chimney type" air flow.
Regardes larry |
Roy Cooke Sr.
http://Royshomeinspection.com
