Im ditching sperry gfci tester
I always keep 2 gfci testers on me, yesterday inspection i was testing a backyard receptacle for gfci, insert sperry tester press the bottom and trips, the receptacle had no reset bottom so i walk around to find connection, reset it and go back to test again, at this time i use kein tester, it was randomly picked. Surprisingly does not trip. Hot ground reverse reading appears on the screen.
I guees the reverse polarity can fool speery tester. Did this ever happen to you?
Your testing methodology is suspect. First job is to verify CORRECT polarity. If that is wrong nothing else matters!
You cannot verify a condition by using two dissimilar pieces of test equipment. You don’t state what the sperry tester indicated before you pushed the button. Consequently yu haven’t told us why you concluded the Sperry instrument was defective as opposed to the Klein.
You need simpler equipment!
You’re right, i did not say why the instrument is defective.
It happened to be a maintenance inspection and the homeowner asked me if i could open it to check and i did. Klein tool was correct.
Also i could not test the receptacle button because there was one , it was connected to another exterior gfci receptacle.
You test the actual GFCI receptacle first, then test the other receptacle to be sure it is disconnected ( tripped). Restore power with the reset butyon and check both outlets for power. Easy peasey!
I know exactly how to test gfci and this not even the point, the point is relying in technology to make your job go faster and smoother and get screwed.
Anyway tools have been replaced and like my friend says and hes a licensed electrician, go back to old school and you cant go wrong.
So you are using a “wiggy” now just as I suggested? Technology will not make your job easier if you don’t understand what, why and how you are testing.
IDK about your specific case but I too carry two testers on me. But I typically use the cheap ones and occasionally they go bad and give a bad reading. That’s why I carry two on me. To double check when something doesn’t seem right. When they start giving a bad reading then I throw it away and put a new one into service. I also put a date on the testers so I know how long I’ve had them in service. I have more expensive testers but I tend to favor the cheaper ones because they fit better in the outlets.
