NYS, Home Inspector CE Approved for 7 hours
http://www.merrellinstitute.com/infraredcertifiedclass.html
http://www.merrellinstitute.com/irinspectoryellowpagesdotcom.jpg
“NOT JUST INSPECTED… INFRARED INSPECTED"TM © Merrell Institute
USE OF INFRARED (IR) CAMERA IN AN INSPECTION** **
7 HOUR CLASS CERTIFICATE**
Saturday, February 28th, '09 8AM TO 3:30PM 7 HOURS-
AN INTRODUCTORY CLASS!
Mail or Fax your registration back to us: Fax #631-563-7719
Merrell Institute Facility: 1461-16 Lakeland Ave., Bohemia, NY 11716
Main School Facility: 631-563-7720 ~ Bill C. Merrell, Ph.D.- School Director/Founder
" ROLL UP YOUR SLEEVES AND EXPECT TO PRACTICE AND USE ONE OF OUR CAMERAS DURING CLASS BREAKOUT’S”
**Infrared (thermal imaging) is an advanced non-destructive technology that allows an Infrared Certified Trained Inspector to show you things about your home that no one can show you with a conventional inspection methods. Infrared inspections can identify and document: (each property is unique and each inspection is unique)
[INDENT][INDENT]
- **electrical faults before they cause a fire. **
- **overloaded and undersized circuits. **
- **circuit breakers in need of immediate replacement. **
- **missing, damaged, and/or wet insulation. **
- **heat loss in walls, ceilings, floors, windows, doors **
- **air infiltration in walls, ceilings, floors, windows and doors. **
- **water and moisture intrusion that could lead to mold. **
- **possible pest infestation. **
- **hidden roof leaks, before they cause serious damage. **
- **air conditioner compressor leaks. **
- **under fastening and/or missing framing members. **
- **structural defects. **
- **broken seals in double pane windows. **
- **energy loss and efficiency. **
- **dangerous flue leaks. **
- **damaged and/or malfunctioning radiant heating systems. **
- **unknown plumbing leaks. **
- overheated equipment
[/INDENT][/INDENT]Want a Free Brochure? Call us at 631-563-7720 or look us up at our main web site:
www.merrellinstitute.com We are InterNACHI CE Approved
