Which one of you guys did I get this from (I love it?)
Recommendation: Video-scan by a Certified Chimney Specialist before closing escrow.
It is impossible for a home inspection to determine with any degree of certainty whether the flue is free of defects. In accordance with recommendations made by the National Fire Prevention Association to have all chimneys inspected before buying a home, you should consider having a Certified Chimney Specialist conduct a Level II inspection of the chimney flue prior to close of escrow.
A Level II inspection is very comprehensive and can better determine the condition of the flue than can a limited generalist inspection or a Level I chimney inspection.
I was hoping they just did crap crowns (called “chimney caps” here) in my areas of inspection. When I explain to a client that is not the better way to finish off a chimney top to shed water and be more durable, I try to find a good example of a full concrete, reinforced crown in the neighbour hood…many times I can’t find even 1 good example within eyesight!!!
